7 members (Woodcmiami, cmayna, Hotrod Lincoln, Gdads51, mick53, MickeyP, 1 invisible),
34
10
Mod | | | Forums66 Topics128,012 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | I have a 53 chevy 3100 does anyone know what battery will fit in the original location and also how many cold cranking amps and cc amps do I need for a 235 motor with a converted 12 v starter ? | | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | As far as size you can just measure the dimensions of the battery box. My rule for CCA as passed down to me from my dad. The highest you can get in a battery that will fit where's it going. The higher you go won't hurt anything, just gives you more cranking power. I see you are in AZ, I'm in northern IL and I have a 700 to 800 CCA batteries in all of my vehicles for the climate we are in.
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | That is the way I fit my batteries too. | | |
