| | | Forums66 Topics128,051 Posts1,055,732 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | Howdy - next somewhat ridiculous question from Bruce....
The interior windshield trim on my 1950 3800 has two little clips, or retaining wires, on the underside of the trim (along with a couple of little foam pads that are glued in). The clips were on either side of the defroster vent opening. Any idea what those little clips do? They didn't appear to be attached to anything when I took the trim off. Any trim clip experts out there?
Bruce | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | As I recall, there are small clips that hold the vent (funnel shaped piece that connects to the vent duct) up against the vent opening in the dash. Perhaps that is what you are referring to. There are two on each side. Kent
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The clips are to keep the vent slits from collapsing if things are jammed against the dash. The small foam pads I believe are anti-squeak in nature.
| | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | Ah! So the clips should probably be positioned within the vent slit, spaced proportionally across the slit. That makes sense. I couldn't see any way that they would attach to the vent itself.
Thanks Brad and Kent!
BV | | |
