4 members (stlcardinalsguy, baldeagle, Ridgeback, KCMongo), 34 guests, and 4 robots.
Topics128,012
Posts1,055,318
Members48,419
#1069518 11/21/2014 4:29 PM
ODSS President
ODSS President
What's cooking? I'll go first.
On the small scale, just replaced my front park/turn bulbs with really bright LEDs and although I don't like the color (bright white) I DO like the fact that I know I will be seen. The emergency flasher mode is just outstanding, well worth the $20+/bulb cost. Had to go with an electronic flasher as I have LED turn/stops in the rear.
Did an oil change from straight 30 weight to a 10-30 for easier starting for this DD through the colder months.
Next....
~ Cosmo
1949 Chevy Half Ton
Cosmo #1069553 11/21/2014 9:28 PM
I still need to work the horn project and the gas level sensor/indicator project on the 62. Otherwise, it depends on what falls off the 66.
~ HB
1962 Chevrolet C10
1962 Suburban
Cosmo #1069556 11/21/2014 9:45 PM
V
VEW Offline
V Offline
I'm preparing a space in my "barn" that I can keep some heat retained..."plastic walls" and celings. If I can get that to work, my plan is to work on "Chief" during the winter months. It needs work from front to rear bumper. I have a 350 and 5 speed tranny that goes in it. I know I need to go through everything else too.
We will see.........best laid plans..........
How come OVERHAULIN doesn't contact me!! smile
~ Victor
1957 3100 - moved on
Cosmo #1069571 11/22/2014 1:10 AM
Hi Cosmo. I'm planning on a rear for my truck... Yeh I got the bug! Wonder where that happened? Think I found one just waiting on the stamping to verify the correct housing. Also I will be updating my turn signals to operate in conjunction with the brake lights, and like yourself, "LED's" with the 6 volt system. Little dark back there! Oh still trying to get the steering a little tighter. But then there is the wife??? A man can dream, right? Then I will be helping old Amtrak Joe with some of his endeavors. God help me! Victor your second in line after overhaulin finishes mine, LOL!
~ Jim Schmidt, Bucks County, PA
1953 Chevrolet 3804 1-ton
In the DITY Gallery
Cosmo #1069575 11/22/2014 1:31 AM
Bondo Artiste
Bondo Artiste
New headlight switch for the 45. Any one shorter than 4 foot 6 wanna lay upside down under my dash and do it for me? Also scored the correct guide R-13 tail light to replace the Ford, yes I said Ford 9N taillight currently on the truck...
For the Burb I need to finish the brake lines that I cut to fit the overdrive transmission I installed back in May. The "Cosmic"
56 rear end gear is installed and once I finish the brake lines it's time for a drive shaft and road test.
And new to the fleet is a 1946 Chevy COE. Big Bertha is her name and she's dying to run again. More to come on that one....
~ Phillip
Cosmo #1069588 11/22/2014 2:46 AM
The 49 is RRRRRREADY FOR PAINT! Need to clean up and paint the seat frame, and heater, and reassemble the 216. Then order $1500.00 in new parts. Does it ever end?
Carl
Cosmo #1069589 11/22/2014 2:46 AM
Camp Commandant
Camp Commandant
Still making steady but slow progress on the 860. The list is endless but lately I have the clutch master set and plumbed, the brake valve gone through and relinstalled, and have spent about two weeks on the accelerator pedal! Obviously that's time spent here and there. At this point in the project, seems like everything is taking lots of time. I have a new headache rack being built (similar to the one that came one the truck) and my taillight housing are almost complete too.
So did you guys catch that, Jr. finally figured out that a big truck may be slower but way cooler! Can't wait to see my 46's ODSS Brother in person!
~ Billy
1959 GMC 860 | Pictures
Cosmo #1069609 11/22/2014 4:35 AM
As soon as I get the new screened in porch done on the back of the house (should be done next week) I'll get back to work on the '56 3100. The list is miles long and I have almost everything needed to finish this 19 year project. The goal is to have it at Homecoming this Spring...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Cosmo #1069610 11/22/2014 4:36 AM
"She's a beut, Clark" The truck has a little while and a bit of work, but, very nice. Very surprised that he made that move,but, an epic save. Me, I plan on working on replacing all the cab seals and flooring on Dempsey.
Mike
1952 Chevrolet 2-Ton 6400
"Dempsey"
Cosmo #1069641 11/22/2014 10:47 AM
OK, I'll add to it. Got to get the gas gauge working. Speedodometer would be nice, I'm using a Garmin gps now. I also need to remove my grille and move it up an inch or so and fix my hood so it will close properly. All this while I'm still driving it and having a blast. Also when is this spring home coming.
Larry
58 gmc 100 with 350 sbc
Cosmo #1069643 11/22/2014 12:06 PM
I'll be finishing up the front end work that I started on the 57 3100. Replacing the king pins and all bushings, new drag link, rebuild the ball joints, then on to adding a sway bar.
And at SOME point, I need to screw up the courage to try welding new skins and bottoms on the doors and fixing their innards.
Boy, I sure miss my old workshop at my last house...
Best to you, Gents
Jim
1957 Chevrolet 3100 Stepside
235, 3-speed w/OD
Cosmo #1069660 11/22/2014 3:50 PM
ODSS Lawman
ODSS Lawman
The elusive 6V LED is something I want to figure out.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Cosmo #1069668 11/22/2014 4:43 PM
6v LEDs bulbs with the right bases seem to be getting more common.
Also, positive/negative ground 6v LEDs are now available.
The "problem" with the LED "bulb" is sometimes the orientation of the individual LEDs relative to the truck-lamp's lens.
Cosmo points out the need to switch from the old style flasher unit to a newer 6v electronic flasher. This is because the old style flasher "flashes" based on current draw - the LEDs draw very little current.
Here is side-by-side LED bulb and normal bulb on Bill Miles' 53 GMC.
Cosmo #1069692 11/22/2014 6:35 PM
ODSS Lawman
ODSS Lawman
Tim
The problem I have with the bulbs is they can only be seen straight on. Unless they've improved lately.
What I want is the full LED board brake lights like you can buy for 12V. I basically want Cosmo's taillights for my 6V setup.
Based on what I've read I'm going to need to master soldering and change the resistors in the 12V setup.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Cosmo #1069731 11/22/2014 11:45 PM
Bond Villain
Bond Villain
Got two here at HQ:
'65 needs a hydrovac rebuild and ole Charlie needs a rewire.
If we get both of those done, we may play with the Meadowbrook some more (the disc brake upgrade). But as that isn't a Stovebolt, maybe I shouldn't be talking about it ... I hope the moderator doesn't zap me...
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
ODSS President
ODSS President
Originally Posted by John Milliman
Got two here at HQ:
Mod-Pres here...
Never been in Hydrovac land, I hear its scenic and sunny there. If you delay long enough we can attack that at The Spring Fling. Sweet and I can rewire Charlie in the time it takes you to fetch us a cold one. Do you have the wiring harness? Charlie merits a nice cloth covered harness. Sweet needs his done and methinks he already has his harness. We'll do a 2 for 1 deal. Start saving large pieces of cardboard so that we can slide around on the deck.
~ Cosmo
1949 Chevy Half Ton
Cosmo #1069746 11/23/2014 1:43 AM
Bondo Artiste
Bondo Artiste
Right on Cosmo!
~ Phillip
Cosmo #1069750 11/23/2014 2:13 AM
ODSS Lawman
ODSS Lawman
I'm in.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Cosmo #1069770 11/23/2014 4:52 AM
Make it 3 trucks. I'll get my wiring harness bought and ready.
Mike
"Dempsey"
Cosmo #1069840 11/23/2014 8:17 PM
Authorized Pest
Authorized Pest
It hope we can get the old fire truck going again. We have needed it to water the compost pile from the collected rain from the pole barn. It will be a good winter project ... we can actually get the fire truck into the garage, so that might help with some warmth. smile
Peg
~ Peggy M
1949 Chevrolet 3804
Cosmo #1069934 11/24/2014 6:41 AM
Where did you buy the cloth wiring harnesses? Do not tell me what they cost. I do not want to know that!
Carl
Cosmo #1069941 11/24/2014 11:58 AM
Camp Commandant
Camp Commandant
Carl, I got my cloth covered harness for my '46 from here
http://www.ynzyesterdaysparts.com/
They probably aren't the cheapest but I was very impressed with the quality. So much that I had them build me a harness for the Big big bolt GMC.
An no, I don't think I want to admit to anyone what I paid for that little bundle of unobtainium!!
There are plenty of others that have what you need.
http://www.stovebolt.com/links/electrical.html
Good luck.
~ Billy
Cosmo #1069943 11/24/2014 12:17 PM
Bond Villain
Bond Villain
Carl,
For what it's worth, I got my cloth-covered harness from Vintage Wiring of Maine. Not sure about YNZ, but VWOM sends along a nicely done and easy to follow installation guide, too. It made rewiring fun (at least when I did it to my '49 BigBolt), plus it will give you something useful to read while you're recovering from the sticker shock in the oxygen tent ... smile
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Cosmo #1070176 11/25/2014 6:10 PM
Authorized Pest
Authorized Pest
Carl,
I don't remember who it was but a recent (last few months) Gallery story had a fellow who used a cloth wiring harness as a replacement. You could post a new thread to see if the fellow shows up ... or go back and read the last 10 or 15 stories.
I was impressed that he still could get a cloth WH. I remember he commented he was glad he went thru the extra effort to get cloth.
(If that helps).
Peg
~ Peggy M
1949 Chevrolet 3804
Cosmo #1070565 11/28/2014 4:01 PM
startinng Body work and paint this wintter
Cosmo #1070611 11/28/2014 11:12 PM
i would like to get the gas gauge, horn, and speedometer working.
But i really need to get the passenger window installed.
Better shutting doors would be nice, need new rubber on the driver door.
Once that gets done it is time to tackle the 261 engine.
Should be a fun winter! leading to a better summer with lots of driving!! - even in the rain!
Alec
Alec
51 Chevy 3100
Cosmo #1070703 11/29/2014 2:45 PM
I'd like to get my cab welded back together enough to install and drive the truck to York for the ATHS show in May. Also hang fenders and a hood on it, headlights would be good.
It'd be smart to swap out the 4.56 axle gears for 3.54 that I already have on hand.
1952 Chevrolet 3800 pickup
---All pictures---
Moderated by  Bill Marlow, SWEET
