4 members (DadsFirstPickup, BC59, Lightholder's Dad, Otto Skorzeny), 127 guests, and 2 robots.
Topics128,135
Posts1,056,422
Members48,441
Z
hmmm.
hmmm.
Z Offline
Is an engine mount adapter that will connect a sidemount for a 1955 235 cc to the position of a frontmount available?
A solution might be to change the timing chain plate to one that has appropiate holes...for front mounting.
Keep the faith and hunker down!
If the plate doesn't have the holes in it you should be able to drill it.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
Z
hmmm.
hmmm.
Z Offline
Yes, I would say yes to that, just spin the engine to a good drill angle and go. Yet, in addition to the new holes, a pressed, rectangle nut in the center is reqired as well. Pretty close to real motor fun to do for me... Or ,
Since I have a front mount plate I can replace with, I would then have to pull the crank gear thing And pull the cam., drop the old plate and replace with a front mount plate.
Thank you for the common sense.
I have made the holes square with a file. If it has a lip that would be the way to go.
Z
hmmm.
hmmm.
Z Offline
Just now I was rummaging thru stuff and found another timing plate that used a 3/4 inch center bolt., no welding. Out of the two, one has to be factory and the other..Frankenstein!.
Ya"lls help means a lot to me. Thanks.
Denny,
Can the same procedure(drill holes in the timing chain plate)be done on a '64 292 for my '53 Chevy 3/4 ton? The 292 currently has a side mount.
Tom B
1953 Chevy 3/4 ton 3600
1964 292 cu. in. in-line six
292's do not have a timing plate like the 216/235's.
My Blog
