1 members (BC59),
211
Mod | | | Forums66 Topics128,087 Posts1,056,106 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 58 hmmm. | | hmmm. Joined: Sep 2011 Posts: 58 | Is an engine mount adapter that will connect a sidemount for a 1955 235 cc to the position of a frontmount available?
A solution might be to change the timing chain plate to one that has appropiate holes...for front mounting.
Keep the faith and hunker down! | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | If the plate doesn't have the holes in it you should be able to drill it. Samantha | | | | | Joined: Sep 2011 Posts: 58 hmmm. | | hmmm. Joined: Sep 2011 Posts: 58 | Yes, I would say yes to that, just spin the engine to a good drill angle and go. Yet, in addition to the new holes, a pressed, rectangle nut in the center is reqired as well. Pretty close to real motor fun to do for me... Or ,
Since I have a front mount plate I can replace with, I would then have to pull the crank gear thing And pull the cam., drop the old plate and replace with a front mount plate.
Thank you for the common sense.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I have made the holes square with a file. If it has a lip that would be the way to go.
| | | | | Joined: Sep 2011 Posts: 58 hmmm. | | hmmm. Joined: Sep 2011 Posts: 58 | Just now I was rummaging thru stuff and found another timing plate that used a 3/4 inch center bolt., no welding. Out of the two, one has to be factory and the other..Frankenstein!.
Ya"lls help means a lot to me. Thanks. | | | | | Joined: Dec 2012 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 61 | Denny, Can the same procedure(drill holes in the timing chain plate)be done on a '64 292 for my '53 Chevy 3/4 ton? The 292 currently has a side mount.
Tom B 1953 Chevy 3/4 ton 3600 1964 292 cu. in. in-line six
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 292's do not have a timing plate like the 216/235's.
See the USA in your vintage Chevrolet! My Blog | | |
