| | | Forums66 Topics128,146 Posts1,056,795 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 237 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 237 | good afternoon, i have a 38 1/2 ton chevy pickup i am trying to fire up. the gas tank i tried to salvage and took to a shop to get it repaired but the guy said he could not guarantee anything and i brought it home and a few months later has passed and now the tank leaks, this is the first time i put gas. i rather buy a new one or a good used one. what years are interchangeable with the 1938? any shops that have (new) one? thanks in advance
| | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | I don't think anyone repops a 38 truck tank. I searched a lot for one for my 38, but had no luck. Sent mine to a tank repair company in Kentucky. Cost about $300 - but gauranteed for life with any fuel. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | oldmemories, if you cannot source a new one why not use a tank sealer kit. There are a couple good ones out there. While nothing beats a new one I did the POR15 kit over 15 years ago with the tank in my '37 and it is doing fine. Takes a little time, better part of the day, but done right it will last. | | | | | Joined: Jan 2011 Posts: 237 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 237 | achipmunk thanks i didnt know they made that stuff, the tank is pretty cleaned from the inside but i will buy this por 15 and use a paintbrush i guess to brush it on unless you recommend something else? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I used Red-Kote on my suburban. Four years and no problems. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Ditto with Cletis, I used RedKote on my '38 almost 10 years ago & no leaks. I did have to braze the larger holes shut before lining. BTW the liner goes on the inside, a brush won't do you any good. If none of that sits with you, you might try these folks.
| | | | | Joined: Feb 2008 Posts: 1,123 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,123 | If you don't want to seal it yourself, another option would be to find a radiator repair shop that also does tank repair. The cost when I had mine done was about $150, as I recall. | | | | | Joined: Jan 2011 Posts: 237 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 237 | thanks for all the replies. | | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | A low cab '36 might fit, the '37 tank fueled from inside the cab, and then you have the '38 tank. I believe that is all the tanks of this size, so it sounds like you all ready know what you have to do. I made a tank for my '37 that fit under the bed, but a good metal worker should be able to make something to fit under the seat. It may not look stock, but its a option.
joe | | |
