5 members (NJC, Otto Skorzeny, UtahYork, MikeStone1953, Hawkman), 97 guests, and 1 robot.
Topics128,057
Posts1,055,810
#1058147 09/23/2014 11:52 PM
my 1960 truck motor has not run in a few years,when I moved it the rear wheels dragged when the clutch was not pushed in. How can I get the motor to turn over with out taking it apart?
thank you for any tips 55 GMC
55 GMC #1058170 09/24/2014 2:05 AM
pull all the plugs soak with WD or diesel. let it set for awhile then retry . but if its that froze dragging it more than likely to froze up and you will have to pull apart.
55 GMC #1058176 09/24/2014 2:27 AM
Put in some Kroil and if you don't have it pour in a 50/50 mixture of diesel and transmission fluid into the spark plug holes and let it set for a week.
Pull the valve cover and "tap" the valves to see if they are stuck, or better yet, pull the rocker assembly and push rods so you don't bend them. Check the lifters to see if they are stuck to.
Then pull the flywheel inspection cover and with a pry bar see if you can get the flywheel to turn. It will take time so be patient.
Let us know how it does.
55 GMC #1058177 09/24/2014 2:35 AM
To fix a stuck motor take out each spark plug and fill every cylinder to the top with your choice of the following. Kroil is the best in my opinion. Other options are diesel fuel, automatic transmission fluid, marvel mistery oil, kerosene, or liquid wrench, WD-40, etc. You can mix these too, such as 50/50 MMO/kero Diesel/atf. Let the substance sit a week then try to turn it over with the starter or you can use a flat screwdriver on the teeth of the flywheel, being careful not to damage teeth. If that doesn't work let it sit for longer. Good luck
55 GMC #1058178 09/24/2014 2:35 AM
I've had the experience of pouring Coca Cola in the cylinders for stuck rings / rusty cylinders and it worked over night !
1947 M15 Studebaker 454 4x4
1949 Chevy COE
More pix of the COE
1950 Harley FL
1958 GMC LCF 455 3x2bbl
1961 Chevy C60 Tilt Cab 327
1966 Chevy C60 Tilt Cab 496
1961 Chevy K10 sb 292
1974 Harley FXE
1979 Chevy K10 sb
2007 Harley Streetglide
I'm not that good but I'm slow
55 GMC #1058185 09/24/2014 2:54 AM
Pour the cylinders full of lightweight oil such as any of the ones mentioned above, take the rocker arms off the valves, and after waiting about a week or more, use the chisel-shaped end of a shepherd's crook wrecking bar in the flywheel teeth at the bottom of the bellhousing and work the flywheel back and forth a little at a time. Don't do any more towing- - - -the connecting rods are sort of flimsy, and they can bend or break if the pistons refuse to move. Patience!
55 GMC #1058705 09/26/2014 7:12 PM
1 Offline
PB blaster works pretty good too.
1947farmer
1947 2-Ton Chevy
Story in the Stovebolt Gallery
More pix in Photobucket
1977 3/4-ton
1985 2.5-ton
2- 1947 Allis WC
1- 1949 Allis allcrop
1- 1955 Allis WD-45
1- 1976 Allis 7040
"If it ain't broke you ain't trying"
