| | | Forums66 Topics128,089 Posts1,055,991 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Not really familiar with these trannys. I have a nice pretty aftermarket speedometer that is operated with a cable. The tranny seems to be for a digital speedo. Short of buying another expensive speedo can the tranny be converted reasonably easy to a cable speedo outlet? Buy the way all this was done by the PO and did not operate when I bought the truck.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not likely to be easier or cheaper than buying a new speedo - these guys will have the info, inquire there with the model numbers from trans and speedo Bill | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Looks like you are right about not being cheaper. Unless I can find a cable operated (if they made such a tranny) 700R4 and scrounge some tail parts off it. Probably just bite the bullet and order a electronic speedo from the same manufacturer as my cable one and sell mine on Craigslist.
| | | | | Joined: Jan 2008 Posts: 140 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 140 | Turbo 400 speedo parts will fit the 700. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, the earlier 700s had mechanical speedos, which is why there's parts to rejig the newer ones > check this for the needed change parts - or there's this adapter [about halfway down], not cheap, but easy Bill | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 |
| | | | | Joined: Jan 2008 Posts: 140 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 140 | I bought all the pieces for a turbo 400 to convert my 700 to mechanical speedo for about $50 off the internet. | | |
