6 members (Cosmo, Gray_Ghost, treegrower, Bill Hanlon, rfs56trk, JW51), 79 guests, and 1 robot.
Topics128,080
Posts1,055,956
Members48,430
Not really familiar with these trannys. I have a nice pretty aftermarket speedometer that is operated with a cable. The tranny seems to be for a digital speedo. Short of buying another expensive speedo can the tranny be converted reasonably easy to a cable speedo outlet? Buy the way all this was done by the PO and did not operate when I bought the truck.
not likely to be easier or cheaper than buying a new speedo - these guys will have the info, inquire there with the model numbers from trans and speedo
Looks like you are right about not being cheaper. Unless I can find a cable operated (if they made such a tranny) 700R4 and scrounge some tail parts off it. Probably just bite the bullet and order a electronic speedo from the same manufacturer as my cable one and sell mine on Craigslist.
Turbo 400 speedo parts will fit the 700.
yes, the earlier 700s had mechanical speedos, which is why there's parts to rejig the newer ones > check this for the needed change parts - or there's this adapter [about halfway down], not cheap, but easy
Thanks guys.
I bought all the pieces for a turbo 400 to convert my 700 to mechanical speedo for about $50 off the internet.
