1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | Any tips on gluing the new rubber and those rivets. I got the little tool and new rivets from Classic Chevy, they don't come with directions and I'm a little confused. Is there some trick to the rubber. My glue job looked terrible, I may need to take it off and start over. Any hints would be appreciated. It's a 58 GMC 1/2 short bed. Thanks Larry
58 gmc 100 with 350 sbc
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Larry, I must have been sent the wrong rivets when I did mine a couple years ago. I could NEVER set one of the rivets, even with the tool that I bought with the rivets. After screwing up a couple pieces of vertical wing vents pieces I glued it on using the 3M stuff. I glued it on, used a clamp and strip of wood to hold it in place overnight. Have not had a problem on my 52 chevy panel. Your 58 GMC may be different than mine. | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | I had to take the vent assy apart to get the rubber to go into the corners, what a mistake. That tool was a joke, it started to deform after a couple uses. Lucky for me I have 4 more vent assys to work with. This is the last thing I have to do to get windows in my truck. I've taken it for a couple short drives and can't wait to get it home. The 48 mile drive to work on it is killing me.
If you remember the pic you saw a coule years ago it looks a lot different now. I painted it Maroon and put a small flat bed on the back with 2 stainless steal tool boxes on it. It looks great and I know there's not another one around my area like it.Larry
