| | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2014 Posts: 52 | Hello I just picked up a 61 Chevy Apache. Currently there are no working turn signals. In a box of extra parts I found a Grote 966-7 turn signal switch which I am unsure if it works or not. I found online what I hope is the wiring colors for these 7 wires. My question is, where do the turn signals get their power from? 4 wires go to the bulbs(RR,RF,LR,LF) ,1 to the brake light switch and 2 to the flasher. In addition, if there are two pig tail wires out of the actual turn signal lights(outside on the truck) how do I know which one of those wires do I connect to from the turn signal switch. I realize this is probably a basic question , but Id rather not fry anything if I do not have to. Thank you | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | The 7-wire switch I purchased from Grote works GREAT! I incorporated it into my American Autowire harness. Grote's color codes/schematics are different than Signal Stat's. If you want to find out the proper schematics for your particular application,you may contact: Grote Industries 2600 Lanier Drive Madison,Indiana 47250. Phone:1-800-628-0809 Business hours are Mon.-Fri. 9:00 A.M.-5:00 P.M. I called them several times,and were very helpful. They even "E-Mailed" a schematic link,which I was able to copy,and use at the job site! The one wire marked "P",(Pilot),may be terminated,if you're planning on using your dash indicators. Your white wire should be "Ground".Hope this helps!
| | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | if the taillights have two wire, the bulbs are mostly likely two-filament. One wire is for the brake light/turn signal (brighter of the two filaments), and one wire is for the taillight (dimmer of the filaments (if the above is true). You wont hurt anything if you hook a wire from the brake/turn signal, and one wire to the taillights. If they're hooked up backwards, you just wont get the noticeable difference in brightness between the brake and turn signal. if that's the case, just switch the wires around
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if the taillights have two wire, the bulbs are mostly likely two-filament. One wire is for the brake light, and one wire is for the turn signal (....) not correct - the 2 wires are tail and brake, the brake light also functions as turn indicator and it's the brighter one Bill | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | right! Thanks for catching that Bill! I MEANT one filament is brake/turn and one taillight! I JUST went through this with mine! You'd think I have everything straight!... went and corrected my first post | | | | | Joined: Aug 2014 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2014 Posts: 52 | Thank you all for your replies. I will keep you posted as to my progress | | |
