5 members (lumbersawyer, tclederman, TUTS 59, 39Master85, 1 invisible), 38 guests, and 3 robots.
Topics128,083
Posts1,056,331
Members48,442
On my 53, while reinstalling the center piece on the windshield the top small bracket that fills the gap between the wind shield trim does not lay flat like the bottom one. They both have the same angle. I removed these pieces over a year ago and they have been in a protected area so have not been damaged. I can't figure what I am doing wrong.
http://i1281.photobucket.com/albums/a506/53Movinon/IMG_2112_zps074838bd.jpg
http://i1281.photobucket.com/albums/a506/53Movinon/IMG_2111_zpsdbf54ca6.jpg
After looking at this again, I suspect that the windshield trim must have a gap at the top to maybe accept part of the headliner? When I reinstalled the w.s. trim I tightened it down flush to the metal behind it as shown. The truck did not have a headliner when I got it. There might have been some rubber shims like the bottom has, but I don't recall seeing any. Any suggestions?
The two pieces should not have the same shape. Maybe one of yours was bent for some reason. Maybe simply bend it back to where it belongs.
David, it was never bent since I've had it. It looks too perfect to be accidently bent. Would you tell me if the w.s. interior trim on your truck is screwed fast to the wide metal strip behind it? If you or anyone has a good picture I could probably figure it out. Thanks for your reply, and would like to hear from more of you guys. Steve
New rubber? I had a heck of a time getting that piece back on my 53.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
If I got it right, that is, what you're asking about, I don't think
the trim pieces fit was all that good when it was delivered back
in '53. Remember, these were utilitarian vehicles, not show pieces.
This is all original, taint been restored, refit or repainted.
Top: http://www.pbase.com/dennygraham/image/157186822
Bottom: http://www.pbase.com/dennygraham/image/157186823
dg
Denny G
Sandwich, IL
Thank you Denny! I was hoping you would respond with a good clear picture. I enlarged the pic of the top and it looks like he headliner tucks in under the windshield trim a tad. That would make it somewhat tighter at the top where the bracket meets the headliner I think. Of course I could always bend it I suppose once the h.liner was in place. Steve
Installing the center windshield trim (inside to outside) was one of the more difficult tasks on the truck assembly process. Patience is required for sure. The top and bottom trim clips were different from another on my truck.
Now I gotta go back and reinstall mine. I put them over the center trim. And they fit just fine. They may have been tweaked some over time but they fit over the center trim just fine. My mirror mount is "T" shaped and covers the top at the headliner gap rather well. So since it would mean fitting into the center trim, PITA. I think on second thought, I will leave it alone. I found mine in one of the boxes of parts the PO gave me when the truck was bought. So when they fit on the outside of the center trim I thought it was how they went.
Steve H
I still don't know if I need to leave the top part of the windshield trim with a gap for the headliner to tuck in.
It won't really matter, since the poor-fitting and soon to shrink cardboard will leave gaps all over the place, in my experience.
Yep what 52Carl said. i had the headliner in before I finished the trim. It was easy and self explanatory. When you start with a empty cab some things just lay into place and others...well, you know where to ask questions. I am impressed and thankful for the sharing of tips and information on this site.
Steve H
Hey 52Carl, what are the choices besides cardboard and fiberglass? I don't like the idea of the second option for a original truck and cardboard sounds really cheap and difficult to install. Does this sound like a common question? Someone must make one that is better than the ones above.
When/if I ever get around to restoring my 50, I plan on taking notes where the poorly fitting areas are due to shrinkage, and make my own headliner with the appropriate corrections.
Same idea here that Carl is planing. I'm going to use my original
one and leave an allowance for shrinkage to be trimmed when I
fit it up. I'm going to use panel board that the upholstery
shops use for door panels and such. It's about the same weight
as the original. Only problem with it is getting the color right.
I've bought one from Jim Carter and one from Classic Parts of Am.
Both are different patterns and made of thin cardboard, much
thinner than the original.
dg
Denny G
Sandwich, IL
Thanks Denny. I am going to check some upholstery shops for that panel board.The only problem is I need a pattern. Steve
52Carl What kind of material will you use?
I bought (and ruined) two sets - one from JC and another one from a local supplier.
I finally bought a set from bowtie_bits on eBay and it fit perfectly. I modified the installation procedure slightly from what I read in the tech tips and it went in beautifully within about 2 minutes. I know we are not supposed to endorse a supplier here but, this head liner is absolutely the best repro I have come across. Supposedly made in America from the original dies.
1951 Chevy 3100 5-Window
"Howard"
More pix on Photobucket
Whatever my adoptive great-half-step-uncle-Denny-in-law once removed, recommends.
Carl
That Peter isn't an endorsement, it's a report, and although I'm
incapable of being a moderator with my temperament, I'd say
report away. Other wise how are we to know where to find the
best bang for our buck.
What I've used for the glove box that I made for my '50, (had to
burn the poor fitting "cardboard ones the vendors sold") was as
I posted, panel board or backer board.
http://www.pbase.com/dennygraham/glove_compartment
Here is just one example of a source for it:
http://www.perfectfit.com/15347/154...Black-Treated-Waterproof-Panelboard.html
It was the standard years ago in the auto upholstery shops when
they needed a ridged backing. It is still used for many projects
today but many shops are using a plastic backer as it has the
advantage that it can be heated and formed to fit.
Do a search for it on the net and you'll spend the rest of the
day surfing.
Here's a detailed tutorial on using the backer board which could
also apply to a headliner:
http://www.hotrodders.com/scratch-built/Upholstery:_Interior_Panels
I know we have some upholsterers here on the bolt, hopefully
one or some will jump in and get their feet wet.
DG
Denny G
Sandwich, IL
U
U Offline
Denny, will you chime in on 53movinon's other headliner thread?
I haven't put enough thought into my idea for a headliner to recommend anything at all, but these two threads are moving parallel to each other. Thanks.
Brad
Wrench Fetcher, PhD
Thanks once more Denny. It's kinda interesting where this post started and what it morphed into. I Googled both of these sites last nite. Perfect F. caught my eye as well as the other one you posted. Thanks to every one else who replied. Now all I need is a pattern! Steve
Moderated by  ndkid275, Phak1
