8 members (55shaker, MickeyP, Bill Hanlon, 3B, Gdads51, Ridgeback, Gray_Ghost, 32Fordpuchoptop), 112 guests, and 1 robot.
Topics128,118
Posts1,056,304
Members48,439
I purchased a roll of the windlace for the engine cowl from Jim Carter, but it doesn't have the embedded wire. I can install it on the front at the radiator end of the cowl, since it's only about 12 inches only there. However, I don't want to use it at the cab end of the cowl, since it's so long that I won't be able to secure it. Anyone know if the original style with the embedded wire is available? I've checked a few sources but can't locate it. Thanks.
1938 Chevy 1/2-ton
More info in the Gallery Forum
She looks good at 50 yards, and 35 miles per hour, on a dark night.
I think I found it on Chevs of the 40s (Item # 374969C). Seems to be reasonably priced, too. Since I made the mistake once already buying the non-wire windlace, any comments on this product?
1938 Chevy 1/2-ton
I bought my 37 stuff years ago from Jcarter and it had the wire in it. Yes, its long and goes down a good ways....and there is a "clip" that fastens the end to the cab/cowl way down low. Mine has lasted years and still looks good but the truck is hardly ever in the bad weather/rain.
I just ran mechanics wire thru mine and it worked great. Bend the leading end over so it dosen't snag and feed it thru. Scott
Ex Hall Monitor
Ex Hall Monitor
Sure you can secure it. I used the wireless on my '38. You have a clip on each end & a hook in the middle of the body radius. These pics are of my coupe. The pickup should be similar. The hook is shaped like a "J" with tail being threaded & a nut inside the cab.
Hook at the belt line radius. One on each side.
End clip. One on each side.
This shows the rubber piece that goes down the forward edge.
