2 members (BC59, Gray_Ghost),
154
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,079 Posts1,056,058 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 103 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 103 | I purchased a roll of the windlace for the engine cowl from Jim Carter, but it doesn't have the embedded wire. I can install it on the front at the radiator end of the cowl, since it's only about 12 inches only there. However, I don't want to use it at the cab end of the cowl, since it's so long that I won't be able to secure it. Anyone know if the original style with the embedded wire is available? I've checked a few sources but can't locate it. Thanks.
| | | | | Joined: Aug 2012 Posts: 103 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 103 | I think I found it on Chevs of the 40s (Item # 374969C). Seems to be reasonably priced, too. Since I made the mistake once already buying the non-wire windlace, any comments on this product? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I bought my 37 stuff years ago from Jcarter and it had the wire in it. Yes, its long and goes down a good ways....and there is a "clip" that fastens the end to the cab/cowl way down low. Mine has lasted years and still looks good but the truck is hardly ever in the bad weather/rain. | | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | I just ran mechanics wire thru mine and it worked great. Bend the leading end over so it dosen't snag and feed it thru. Scott | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I don't want to use it at the cab end of the cowl, since it's so long that I won't be able to secure it. Sure you can secure it. I used the wireless on my '38. You have a clip on each end & a hook in the middle of the body radius. These pics are of my coupe. The pickup should be similar. The hook is shaped like a "J" with tail being threaded & a nut inside the cab. Hook at the belt line radius. One on each side. End clip. One on each side. This shows the rubber piece that goes down the forward edge.
