1 members (J Lucas),
85
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I think that's what it's called? That plastic strip with the outside bead put between the fender and cab. Anyways. Does it come in different thicknesses?
TIA
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, fender welt - the thickness of the flap and the bead are standard from all I've seen, and pretty thin
Bill | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | And the repo stuff is not close to the original stuff ...pic... | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | If you want black and some good stuff buy some that goes on a VW. Its the real deal and will look good .....at least as long as we live. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I've used the chrome welting sold by J. C. Whitney.... They also have it for VWs and even offer it in other colors.
John | | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | I never understood what this was for originally, to hide bad panel fitment? Are you guys using this because you want an original look or to stop squeaks or to keep trash out of the joint? The reason I ask is I was considering using a plastic washer between the fender and the bed and didn't know if that was a ridiculous idea or not.
36 Chevy 1.5 ton - rusting away 52 Chevy 3100 - in progress 72 Chevy K20 - DD
PANTS UP DON'T LOOT! PANTS UP DON'T LOOT!
NEVER watch another man eat a banana.
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | My 46 never had any. I used black cloth duct tape to avoid squeaks (not visible). I like the look without the welting. | | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | Thanks GW. I tend to agree that, at least from the few that I have actually seen, the repo stuff just doesn't look all that great. I would love a picture from someone who had it come out the way they had hoped.
| | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | Scott Here's a picture of the front fender welt on an un-restored '49 GMC '49 and my '52 GMC I recently completed. '52 I am very happy with the way it turned out. As you are probably aware the welting was only used on the front fenders presumably as both an anti-squeak and to keep debris from building up in the fender to cowl joint. The front end of the welt is tucked between the filler plate and front fender. welt The welting I used was very much like the original with the bead sewed to a cloth like material. Unfortunately I got this material with some other used parts I purchsed and don't know where it came from originally. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Like Alvin I used the VW stuff,you can buy in I think it was a 25' roll. It's not expensive,and stops crud building up between the fenders and bedsides. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Nov 2011 Posts: 1,610 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,610 | I didn't like the quality of the many vinyl products out there, and the VW welting did not seem to be wide enough to extend the entire distance of the fender flange. I found a source for real rubber welting, and was happy with the results. http://cgfordparts.com/CATPICS/LOGOTHUMB/0000024352_0035000400.JPG | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 |
Error 1011 Ray ID: 1584053a180c0406 Access denied What happened?
The owner of this website (cgfordparts.com) does not allow hotlinking to that resource (/CATPICS/LOGOTHUMB/0000024352_0035000400.JPG).
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I used the welting as pictured in DADS50's post both on my front and rear fenders with success. As shown in his photo cutting those types of bolt reliefs is key to a good fit (and 3M weatherstrip glue). I sharpened a 1/2 pipe nipple on my bench grinder as a punch to make the holes and the cut the remainder with scissors. It has held up well and while the factory may not have applied it to the rear fenders I think it finishes them off. I will take a close-up shot but here you can see the welt on the rear. https://www.flickr.com/photos/advance-design_parts_co/8129208312/in/set-72157631867396207 | | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | I guess I figured that the welting worked from above but didn't work so great from beneath. I like the idea of the welting fitting the entire width of the flange.
Paul - what year vehicle did you use to get your welting?
Thanks for the help!
| | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | Hey Paul - never-mind. I see that year does not matter, it is all the same. This is good looking stuff and comes in several colors.
Thanks again.
| | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | for those of you interested, you could also make your own welting in whatever color you wanted. I saw a video/tutorial somewhere along the web. Probably what I will do when time comes, I can't recall ever seeing a brown welting which is what I'd go for | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you can make welting using upholsterer techniques, like this door seal custom made for my bus Bill | | |
