0 members (),
83
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 28 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 28 | I was under the '46 2 Ton doing a chassis grease & general inspection and had an opportunity to closely examine the battery box. The box is under the passenger floorboard and is more an arrangement of heavy steel flatbars than an actual box. There is an access panel in the floorboard but it's just barely large enough to access the cell caps; nowhere near big enough to lift the battery out through.
A few of the flatbars comprising the battery box have carriage bolts but only on one end. For that matter all but one carriage bolt have their heads inside against the battery so I can get the nuts off but I can't get the bolts out.
How, exactly, is one supposed to get the battery out of this thing? I'm sure it's something simple I'm overlooking but I'd better figure it out before it's time to replace.
Pete P. Harborcreek, Penna.
| | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | The only way to remove the battery is to unbolt the entire floor board. | | | | | Joined: Aug 2012 Posts: 28 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 28 | Ugh. Not one of GM's better ideas.
At least I know what I'm up against.
Pete P. | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | The battery got IN there somehow,it has to be able to get out the same way. I'm thinking there's some braces than would unbolt and the battery would come out from under the truck. Speed | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | in my 46, I just cut the floor hole large enough to get the battery in/out and made a new cover for it  Bill | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Yeah, it was not the best design. My method to work around the issue was to get a high quality battery so hopefully I won't have to "experience the joy" of taking the floor apart but once every 7 years or so. That's the plan anyway. | | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | Yeah, it was not the best design. I thought the military trucks had the battery mounted behing the running board. Is yours too early for that? | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | The early production 1940-march 1942 YP and ZP military trucks had the battery under the floor the same as civilian. I think the change occurred when they went from 25 amp positive ground to 40 amp negative ground. At least that is what the parts manuals indicate. | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I saw one a while back that was under the floor,and the guy used the front cover for a breaker box to cover the hole. I'd thought about doing that trick when I changed to a dual reservoir master cylinder,but I was too cheap to buy a box just for the cover. It DOES work well,and looks pretty nice though. Speed | | |
