Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (55shaker, Wayne67vert), 118 guests, and 4 robots.
Topics128,281
Posts1,058,465
Members48,490
#1046233 08/01/2014 12:37 AM
I was under the '46 2 Ton doing a chassis grease & general inspection and had an opportunity to closely examine the battery box. The box is under the passenger floorboard and is more an arrangement of heavy steel flatbars than an actual box. There is an access panel in the floorboard but it's just barely large enough to access the cell caps; nowhere near big enough to lift the battery out through.
A few of the flatbars comprising the battery box have carriage bolts but only on one end. For that matter all but one carriage bolt have their heads inside against the battery so I can get the nuts off but I can't get the bolts out.
How, exactly, is one supposed to get the battery out of this thing? I'm sure it's something simple I'm overlooking but I'd better figure it out before it's time to replace.
Pete P.
Harborcreek, Penna.
The only way to remove the battery is to unbolt the entire floor board.
Ugh. Not one of GM's better ideas.
At least I know what I'm up against.
Pete P.
The battery got IN there somehow,it has to be able to get out the same way. I'm thinking there's some braces than would unbolt and the battery would come out from under the truck.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
in my 46, I just cut the floor hole large enough to get the battery in/out and made a new cover for it wink
Yeah, it was not the best design. My method to work around the issue was to get a high quality battery so hopefully I won't have to "experience the joy" of taking the floor apart but once every 7 years or so. That's the plan anyway.
Lots more pictures
I thought the military trucks had the battery mounted behing the running board. Is yours too early for that?
The early production 1940-march 1942 YP and ZP military trucks had the battery under the floor the same as civilian. I think the change occurred when they went from 25 amp positive ground to 40 amp negative ground. At least that is what the parts manuals indicate.
Lots more pictures
I saw one a while back that was under the floor,and the guy used the front cover for a breaker box to cover the hole. I'd thought about doing that trick when I changed to a dual reservoir master cylinder,but I was too cheap to buy a box just for the cover. It DOES work well,and looks pretty nice though.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'84 Bronco II
'78 Dodge W-200
