9 members (Otto Skorzeny, Gdads51, Paul Mullen, DavidBraley, TUTS 59, Ponchogl, Shaffer's1950, JoergK., mk72), 118 guests, and 4 robots.
Topics128,184
Posts1,057,196
Members48,465
Does your advance design truck squeak going down the road? I have greased the spots I can grease. Do the leaf springs make a lot of noise when going over bumpy roads? I can't tell if they have rusted and squeak when going over rough roads or if it is coming from somewhere else? Any ideas on how to make it quieter? Has anyone else experienced this? Thanks in advance
Mike Doak
Leo Offline
Moderator
Moderator
Mine squeaks and creaks. Short of sealing up the cab with sound deadener, I'm not sure what you can do.
I think what you are experiencing is what we all enjoy at various decibel levels. These trucks even when reassembled like mine in a frame-off have numerous metal on metal points of contact. I just enjoy it as part of the experience as I don't feel chasing them all down is really practical.
KMAC
Thanks, it would take a LOT of sound deadner! I appreciate the reply.
Thank you I did spray some solvent on the springs to see if it helps any.
Creaks, rattles, squeaks, groans, more rattles.... Mine's just fine. I'm OK with rattles, but squeaks really bug me and I try to find them.
As Click & Clack often recommend, just turn up the radio and enjoy the ride!
Cheers!
Cheers!
Love those two guys!
Ex Hall Monitor
Ex Hall Monitor
Leaf springs can and do indeed squeak. My '38's springs squeak. You can buy spring separator or squirt some grease between the springs but most of us just listen to the "symphony" as we drive. grin
I found an old "magic carpet" (a snow slider) at a garage sale. Paid a buck and sliced it into 1 3/4" strips which I placed between my spring leaves. Seems to work but after a while the slip out sideways. You can buy the rubbery stuff with a ridge on each side to keep it in place. Bob Drake Ford parts sells it.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Nothing to worry about,it's just 'talking' to you.
Look at any youtube video of in-cab shots of these old trucks driving and you'll see (hear) you're not alone. grin
More pix on Flickr.
If you have an old, tired, well worn truck, it would be wise to try to find where the noises are coming from and see if it poses a safety threat. Some things that come to mind are, broken springs, badly worn spring shackle bushings, worn king pins or tie rod ends.
Carl
V
V Offline
After a complete frame off mine still squeaks. We just turn up the serious radio and it all goes away when were out cruising to the tunes. LOL
Thanks good to know!
No, springs are ok, we replaced one and have a new front end. I think maybe the leaf springs rusted some after driving the truck more and are making more noise. Right front leaf spring causes a lot of noise when going over big bumps. I am going to get underneath and try some oil and grease on the leaf springs and see if it gets quieter. Doesn't bother me that much, just trying to get a little more of a quiet ride. Good roads I hear nothing, unfortunately most roads now days are going (bad).
Ha, I am not going to do the frame off so guess I will put up with the noise.
Thanks for all the comments, concern, and advice.
Mike Doak
WOW, just looked at your photos of your truck. BEAUTIFUL great restoration!
