0 members (),
130
Mod | | | Forums66 Topics128,077 Posts1,056,034 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 89 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 89 | Hello folks need your help once again.I went to look at another 54 3100,It has a butterfly steering wheel ,was that an option that was available? Also it has a 4 speed on the floor,I'm trying to determine if that trans. is original to the truck.The floor pan trans. cover has been cut,it appears to have been cut with a torch.Does the trans. floor panel come from the factory that way or is it a much more finished piece?
PS The engine has been changed.It has a 54 car engine in it. I believe it is a 235 but it has acorn valve cover nuts.Engine #0219787f54z | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | No butterfly steering wheel was a GM option or accessory on a 1954 truck (the only different steering wheels might be the color on deluxe two-tone interior 54/55 trucks).
Please post a link to a photo, it would be interesting to see it.
There was a different standard/factory floor cover for 3-speed, 4-speed, and Hydra-Matic transmissions.
Do you still have an enclosed drive-shaft?
2-bolt covers were not standard equipment in 1954, but it is easy to use them on a 54 and later head with an older valve cover. If you have taken the valve cover off, are there 4 holes in the head around the base of the valve cover?
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | That butterfly sounds like a passenger car option but I've seen several different accessory steering wheels in trucks. I believe the shaft/splines are the same, not sure about horn contact parts. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | simplex,
That 20" steering wheel would be very nice for people with little-or-no clearance between their body and the wheel.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | What is a butterfly steering wheel? Does it refer to the center Medallion ? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | DADS50, I had the same question. I assume they are referring to most of these? I like the one you found, with the clock at the top. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Thank you
Those wheels are cool, I like the horn ring also. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | So.....have we established whether they were optional, from a Chevrolet car, from a different maker, aftermarket or what? Also that one with the clock in it is the only one of it's kind that I've ever seen. Wonder if it wasn't custom made.
DG
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Denny, If a butterfly steering wheel was optional on a 54/55st Chevrolet truck, it most likely came with the Power Steering option that Lares Corporation assures me was available on 1954 Chevrolet trucks. This is after Lares sent me an incorrect steering assembly, and then told me that my 5 assemblies were all wrong. Luckily, I bought the assembly through Rockauto.com, who gave me full refund, including shipping back to Lares. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | What is a butterfly steering wheel? Does it refer to the center Medallion ?I think the name refers to the general shape of the horn ring as it is similar to wings. Not the medallion. If you have seen a drag steering wheel on a fuelie drag car, it is a butterfly wheel.
Drew
