0 members (), 133 guests, and 2 robots.
Topics128,157
Posts1,056,876
Members48,458
It is official, we have lost the keys. I remember my Dad handing them to me the morning we left Wyoming, but after 6 weeks of searching I can't find them.
What are the options for replacement keys? Can a good locksmith cut new keys if I bring the ignition in?
Any concerns about the key blanks through the normal channels?
Any help / ideas welcome.
~Justin
1937 Chevy 1/2-ton
"Wylburr Clyde"
More pictures on Google
My Grandfather bought it new and Dad drove it through highschool. The 3rd & 4th generations put it back on the road on 8/8/2015!
Absolutely no problem for a GOOD locksmith.
Justin, I always check the "black hole" where everything slides down between the driver seat and the middle section....
martin is correct and most all key men I know have the correct blanks around here.
Do the same keys lock/unlock the door? If not, I suggest you buy an after market ignition switch, such as those made by Standard, find a GM blank(s) and have it cut to the ignition form the key that comes with the ignition. Install the ignition and then you should be OK.
The door lock / handle has the key code on it. I took mine in and had a key cut for the door in a matter of minutes. I would bet the ignition is the same way.
Joe, the replacement door handles Chevrolet made never had a code stamped on them. My guess is this one doesn't or he would have asked about the numbers stamped on the handle. That's why I suggested going in the other direction. If the numbers ARE stamped on the door handle---GREAT---that's all he needs!
