2 members (RoadsScholar, 1 invisible),
154
Mod | | | Forums66 Topics128,087 Posts1,055,976 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2001 Posts: 37 Junior Member | | Junior Member Joined: Jun 2001 Posts: 37 | Can anyone show me or explane to me how the parking light housings are attached to the headlight buckets on a 46? there are two screw holes on top of housing, just wondered how they originaly attached to bucket. Someone had welded studs to bucket with acorn nuts holding housing on. I know thats not right
"Boop-Boop-a-doop"
| | | | | Joined: Apr 2000 Posts: 71 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 71 | Mine has 2 sheetmetal screws from the top, screwed into the headlight housing. I had to use a wood screw for the long one, because I couldn't find a sheet metal screw that long. | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | I added a couple of pictures that show two different headlight buckets including the screws. Both were unrestored buckets. Just click on my link below. Should be able to find it at the end of the "46 Chevy" pictures. If you need any other pictures let me know. I also added a couple so you can see the small clip that snaps in the bucket that actually grabs the screws. Hopefully this will help!
Good Luck
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | What T shows you is exactly right. Thats the way my '46 Panel is set up to attcah also.
David Just a firefighter, Cleverly disguised as a responsible adult '46 1/2 T Panel
| | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Does anyone know if those clips are available anywhere? I sure could use a couple. Thanks George | | | | | Joined: Jun 2001 Posts: 37 Junior Member | | Junior Member Joined: Jun 2001 Posts: 37 | Ok...Thanks for the pics...I see now how it goes. I wonder where I might find those clips..Too. Maybe just tack a nut on inside of bucket housing?Thanks for the help.
"Boop-Boop-a-doop"
| | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Nice job documenting your work Tim.  | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | Thanks Rusty! This is my first full restoration and I have read that the pictures end up being extremely important. With a digital camera it costs nothing so I figure it should help me and others as they get stuck. At least twice now I have been able to help others with my pics. Hopefully many more as time goes on. I'm sure I'll love looking back at them too. I've only posted about 1/3 of the pictures I have.
