3 members (55shaker, Jon G, BillCollins), 113 guests, and 2 robots.
Topics128,080
Posts1,055,956
Members48,430
#103349 12/08/2003 6:21 PM
Junior Member
Junior Member
Can anyone show me or explane to me how the parking light housings are attached to the headlight buckets on a 46? there are two screw holes on top of housing, just wondered how they originaly attached to bucket. Someone had welded studs to bucket with acorn nuts holding housing on. I know thats not right
"Boop-Boop-a-doop"
#103350 12/09/2003 2:53 AM
Mine has 2 sheetmetal screws from the top, screwed into the headlight housing. I had to use a wood screw for the long one, because I couldn't find a sheet metal screw that long.
#103351 12/09/2003 4:29 AM
I added a couple of pictures that show two different headlight buckets including the screws. Both were unrestored buckets. Just click on my link below. Should be able to find it at the end of the "46 Chevy" pictures. If you need any other pictures let me know. I also added a couple so you can see the small clip that snaps in the bucket that actually grabs the screws. Hopefully this will help!
Good Luck
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
#103352 12/09/2003 4:35 PM
What T shows you is exactly right. Thats the way my '46 Panel is set up to attcah also. grin
David
Just a firefighter,
Cleverly disguised as a responsible adult
'46 1/2 T Panel
#103353 12/09/2003 6:24 PM
Does anyone know if those clips are available anywhere? I sure could use a couple.
George
#103354 12/09/2003 8:43 PM
Junior Member
Junior Member
Ok...Thanks for the pics...I see now how it goes. I wonder where I might find those clips..Too. Maybe just tack a nut on inside of bucket housing?Thanks for the help.
"Boop-Boop-a-doop"
#103355 12/09/2003 9:34 PM
Nice job documenting your work Tim. smile
#103356 12/10/2003 4:17 AM
Thanks Rusty! This is my first full restoration and I have read that the pictures end up being extremely important. With a digital camera it costs nothing so I figure it should help me and others as they get stuck. At least twice now I have been able to help others with my pics. Hopefully many more as time goes on. I'm sure I'll love looking back at them too. I've only posted about 1/3 of the pictures I have.
Tim Sheridan
