| | | Forums66 Topics128,079 Posts1,056,303 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 131 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 131 | Has anyone advice on a backlite conversion for my 62? A chap in Montana makes new inner panels for the large glass. But I do not have his contact Info. Any help in this area will be appreciated.
Thanks, Howie
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine 4 1966 Plymouth VIP 5.7 GenIII Hemi 5 1966 Imperial Crown Coupe 440 engine | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | | | | | | Joined: Feb 2014 Posts: 215 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 215 | You can use any window of your choice. My 64 C20 happens to have a 71 Ford slider. We're pulling it to put in a one piece glass; no slider. It looks like the sheet metal was just cut to fit, and the window installed with a new seal (looks a bit flimsy to me but it's been in there a long time). It'll be interesting to see what they actually did when we pull the old window. The new one will be put in correctly regardless. I also installed one piece power side windows. What a project that was! | | | | | Joined: Sep 2011 Posts: 131 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 131 | I made contact with Scott Hursh in Great Falls Mt. His Classic Big Window.com has the info on what he makes. Seems like a nice chap that enjoys old Chevys.
3 1962 Chev c-10 261 engine 4 1966 Plymouth VIP 5.7 GenIII Hemi 5 1966 Imperial Crown Coupe 440 engine | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Just need an inner panel and glass from a donor truck. | | | | | Joined: Aug 2014 Posts: 1 Moderated | | Moderated Joined: Aug 2014 Posts: 1 | Do you still have Scott Hursh's contact imfo?? Would love to convert my 64 to a big back window. | | | | | Joined: Sep 2011 Posts: 131 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 131 | Howdy Dez Scott's contact is Classic Big Window.com (406)781-1296 in Great Falls Mt.
He and his son are quite busy in there small restoration shop. He produces by hand a excellent replacement inner panel and template with instructions to modify your truck.
Good luck with your project. Howie
3 1962 Chev c-10 261 engine 4 1966 Plymouth VIP 5.7 GenIII Hemi 5 1966 Imperial Crown Coupe 440 engine | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Has anyone advice on a backlite conversion for my 62? A chap in Montana makes new inner panels for the large glass. But I do not have his contact Info. Any help in this area will be appreciated.
Thanks, Howie the 60-66 FAQ Index Section 2A
Big Back Window ConversionYou may find some tips, good advice in some of those threads. Good luck, -W | | |
