3 members (GRNHydra, rfs56trk, Ole49GMC), 152 guests, and 1 robot.
Topics128,076
Posts1,056,280
Members48,441
Has anyone advice on a backlite conversion for my 62?
A chap in Montana makes new inner panels for the large glass. But I do not have his contact Info.
Any help in this area will be appreciated.
Thanks, Howie
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine
4 1966 Plymouth VIP 5.7 GenIII Hemi
5 1966 Imperial Crown Coupe 440 engine
You can use any window of your choice. My 64 C20 happens to have a 71 Ford slider. We're pulling it to put in a one piece glass; no slider. It looks like the sheet metal was just cut to fit, and the window installed with a new seal (looks a bit flimsy to me but it's been in there a long time). It'll be interesting to see what they actually did when we pull the old window. The new one will be put in correctly regardless. I also installed one piece power side windows. What a project that was!
I made contact with Scott Hursh in Great Falls Mt.
His Classic Big Window.com has the info on what he makes.
Seems like a nice chap that enjoys old Chevys.
Just need an inner panel and glass from a donor truck.
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Dez Offline
Moderated
Moderated
Do you still have Scott Hursh's contact imfo?? Would love to convert my 64 to a big back window.
Howdy Dez
Scott's contact is Classic Big Window.com
(406)781-1296 in Great Falls Mt.
He and his son are quite busy in there small restoration shop. He produces by hand a excellent replacement inner panel and template with instructions to modify your truck.
Good luck with your project. Howie
Here's Stovebolt member MyBlueChevy's page on the conversion. Using OEM inner sheet metal gives the finished product a factory look inside the cab.
http://1958evinrude10hp.0catch.com/60-61BackWindowProjectPg1.html
Socket Breaker
Socket Breaker
Thanks, Howie
the 60-66 FAQ Index
Section 2A
Big Back Window Conversion
You may find some tips, good advice in some of those threads.
Good luck,
-W
