0 members (), 117 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
Junior Member
Junior Member
I just bought a new dome light and I went ahead and ripped the old one out, but I was wondering how to get the plug and cord of the new one all the way from the back to the hole where it will come out right behind the gas cap and neck. I tried using a wire hanger to push the plug head through, but it keeps getting jammed. Sorry if my wording is a little confusing. Oh ya and the truck is a 62' c10.
62' c10
adamsbomb,
I don't know your particular situation, but it's pretty common for us old Millwrights to use the OLD wire to pull the NEW wire. smile
You can use the old wire to pull a pulling string, then use this string to pull a new wire...sounds confusing, but it's simple if you have any of the original wire intact.
Stuart
Junior Member
Junior Member
no I get it. Ill go ahead and try that right now. Thanks!!
62' c10
Junior Member
Junior Member
ok well i did what you said and it worked great, but now that i plugged it in, the light stays on all the time. So I was wondering what part do i need now to shut the light off when I shut my door. Sorry, but if you didn't notice I am a newbie to cars, but I'm learning fast! lol
62' c10
turn the headlight knob
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Junior Member
Junior Member
ah lol, ill go try that. Lol my bad. It works just fine.
62' c10
Junior Member
Junior Member
alrght, just so I dont have create another thread, how do you install a speedometer cable?
62' c10
the cable and not the housing and cable simply pull the cable out of the housing either thru under the dash or out of the transmission side. to undo the speedo side there is a slip clip you have to get undone from the back of the speedometer pretty simple design take your time you will see what I am talkin about. remember to grease the cable liberally before you reinstall.
Junior Member
Junior Member
ok, sounds good. Thank you.
62' c10
Junior Member
Junior Member
Ok so I see where the cable hooks into the dash area behind the instrument cluster, but where does the other end go?
62' c10
Into the transmission.
My 1953 Chevrolet
1947.1 Gallery
