1 members (BC59),
211
Mod | | | Forums66 Topics128,087 Posts1,056,106 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 10 Junior Member | | Junior Member Joined: Sep 2007 Posts: 10 | I just bought a new dome light and I went ahead and ripped the old one out, but I was wondering how to get the plug and cord of the new one all the way from the back to the hole where it will come out right behind the gas cap and neck. I tried using a wire hanger to push the plug head through, but it keeps getting jammed. Sorry if my wording is a little confusing. Oh ya and the truck is a 62' c10.
62' c10
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | adamsbomb, I don't know your particular situation, but it's pretty common for us old Millwrights to use the OLD wire to pull the NEW wire. You can use the old wire to pull a pulling string, then use this string to pull a new wire...sounds confusing, but it's simple if you have any of the original wire intact. Stuart | | | | | Joined: Sep 2007 Posts: 10 Junior Member | | Junior Member Joined: Sep 2007 Posts: 10 | no I get it. Ill go ahead and try that right now. Thanks!!
62' c10
| | | | | Joined: Sep 2007 Posts: 10 Junior Member | | Junior Member Joined: Sep 2007 Posts: 10 | ok well i did what you said and it worked great, but now that i plugged it in, the light stays on all the time. So I was wondering what part do i need now to shut the light off when I shut my door. Sorry, but if you didn't notice I am a newbie to cars, but I'm learning fast! lol
62' c10
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | | | | | | Joined: Sep 2007 Posts: 10 Junior Member | | Junior Member Joined: Sep 2007 Posts: 10 | ah lol, ill go try that. Lol my bad. It works just fine.
62' c10
| | | | | Joined: Sep 2007 Posts: 10 Junior Member | | Junior Member Joined: Sep 2007 Posts: 10 | alrght, just so I dont have create another thread, how do you install a speedometer cable?
62' c10
| | | | | Joined: Apr 2006 Posts: 20 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 20 | the cable and not the housing and cable simply pull the cable out of the housing either thru under the dash or out of the transmission side. to undo the speedo side there is a slip clip you have to get undone from the back of the speedometer pretty simple design take your time you will see what I am talkin about. remember to grease the cable liberally before you reinstall. | | | | | Joined: Sep 2007 Posts: 10 Junior Member | | Junior Member Joined: Sep 2007 Posts: 10 | ok, sounds good. Thank you.
62' c10
| | | | | Joined: Sep 2007 Posts: 10 Junior Member | | Junior Member Joined: Sep 2007 Posts: 10 | Ok so I see where the cable hooks into the dash area behind the instrument cluster, but where does the other end go?
62' c10
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | | | |
