0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 22 New Guy | | New Guy Joined: Mar 2005 Posts: 22 | Going searching for a T5 to put in my 52 3100. I would like to keep the foot starter. Does changing to the T5 prevent this. I will be using one of the adapter plates on the market between the trans and bell housing.
Doug
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Shoundog, If you plan to use a T5 from an S10, I think I can help you avoid buying an adapter plate. The 14 spline S10 input shaft can usually be exchanged with a BRAND NEW 10 spline T5 input shaft made for a Jeep T5. The new T5 shaft would cost about $75 total. The swap is not difficult but I'm not sure how comfortable you would be doing it. I also sent you a PM. This article in the Stovebolt TECH TIPS section probably has the info you need to keep the foot starter, but I have not read through it. Here's another article. And one more article.
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | My '46 261/stock bellhousing/flywheel, AstroVan clutch disc,stock pressure plate-almost 11", running T-5 and foot starter, no probs. I had to have an adapter because of 46 small trans pattern to bellhsng, your 51 has same pattern as T-5 but must make some mods as Lugnutz expained. Lots of tech tips on the T-5s on this site and over on Inliners.org plus others, read them all. Love my T-5. Best of luck | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You use the existing bell housing & you can retain the stomp starter. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2005 Posts: 22 New Guy | | New Guy Joined: Mar 2005 Posts: 22 | Thanks to all so far. Lugnutz PM'd you back. Not out of my comfort zone, been twisting wrenches for 45 years from airplains to locomotives. Age makes me think a lot longer to make sure it is right and I dont't hurt myself.
Doug
