0 members (), 46 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#1029757 05/19/2014 6:16 PM
Going searching for a T5 to put in my 52 3100. I would like to keep the foot starter. Does changing to the T5 prevent this. I will be using one of the adapter plates on the market between the trans and bell housing.
Doug
shoundog #1029759 05/19/2014 6:34 PM
Shoundog,
If you plan to use a T5 from an S10, I think I can help you avoid buying an adapter plate. The 14 spline S10 input shaft can usually be exchanged with a BRAND NEW 10 spline T5 input shaft made for a Jeep T5. The new T5 shaft would cost about $75 total. The swap is not difficult but I'm not sure how comfortable you would be doing it.
I also sent you a PM.
This article in the Stovebolt TECH TIPS section probably has the info you need to keep the foot starter, but I have not read through it.
Here's another article.
And one more article.
shoundog #1029766 05/19/2014 7:23 PM
My '46 261/stock bellhousing/flywheel, AstroVan clutch disc,stock pressure plate-almost 11", running T-5 and foot starter, no probs. I had to have an adapter because of 46 small trans pattern to bellhsng, your 51 has same pattern as T-5 but must make some mods as Lugnutz expained. Lots of tech tips on the T-5s on this site and over on Inliners.org plus others, read them all. Love my T-5.
Best of luck
1946 1/2-Ton Chevy
shoundog #1029804 05/19/2014 9:38 PM
Riding in the Passing Lane
You use the existing bell housing & you can retain the stomp starter.
1972 Chevy c10 Cheyenne Super
shoundog #1029807 05/19/2014 9:51 PM
Thanks to all so far. Lugnutz PM'd you back. Not out of my comfort zone, been twisting wrenches for 45 years from airplains to locomotives. Age makes me think a lot longer to make sure it is right and I dont't hurt myself.
Doug
