0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | I put direction lights on my '46 6400 last year and they worked OK until just a couple of weeks ago when the flasher started going really fast. I put a new 6-volt flasher in and noticed that it is labeled for not more than 4 bulbs. When I plug in my trailer, there are 3 bulbs per side (6V bulbs in trailer) and if I use the hazards, that's 6 bulbs. Since flashers work on current, I'm wondering if a 12v heavy duty flasher would work. I suppose I could go out, buy one and try it, but I thought I would check to see if anyone has done that already. Thanks. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...usually if the flasher is flicking on and off real fast you simply have a bulb burnt out? Never done what your talking about though. | | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | The bulbs are all lighting.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Generally 12V stuff can't handle 6V for very long, but I've never tried a 12V flasher on 6V. | | |
