5 members (Gdads51, Chris_Welch, homer52, texas46, 1 invisible), 154 guests, and 4 robots.
Topics128,267
Posts1,058,386
Members48,485
#1028916 05/16/2014 12:37 AM
I put direction lights on my '46 6400 last year and they worked OK until just a couple of weeks ago when the flasher started going really fast. I put a new 6-volt flasher in and noticed that it is labeled for not more than 4 bulbs. When I plug in my trailer, there are 3 bulbs per side (6V bulbs in trailer) and if I use the hazards, that's 6 bulbs. Since flashers work on current, I'm wondering if a 12v heavy duty flasher would work. I suppose I could go out, buy one and try it, but I thought I would check to see if anyone has done that already. Thanks.
...usually if the flasher is flicking on and off real fast you simply have a bulb burnt out? Never done what your talking about though.
The bulbs are all lighting.
Generally 12V stuff can't handle 6V for very long, but I've never tried a 12V flasher on 6V.
My 46 GMC on Photobucket
