3 members (TooMany2count, 32Fordpuchoptop, Hotrod Lincoln), 92 guests, and 3 robots.
Topics128,141
Posts1,056,485
Members48,441
Hey I know there is a million posts on this but when I search I can't seem to find the one I'm looking for anymore. I thought I had read here that you could still use your 6v generator with a 12v system? Is this correct?. Also do I need a ballast resistor even if I'm replacing the points with a electronic ignition system? Not really sure what the ballast resistor is for between the ignition switch and the coil but I'm assuming that is what it is for.Thanks
Paul
You will need to switch to a 12-volt generator or have your's rebuilt with the proper coils. I will leave the ballast resistor thing alone as that has been debated ad nauseam.
I have a 12 volt generator just not sure of the condition that's why I asked on that one. It's a little bit of a travel for someone to work on it here in Milwaukee. Alot of places won't touch it . I'm still searching the posts for the one were someone was talking about using the 6v gen on a 12 v system.
Only way to make a 6 volt genny work at 12 volts would require the armature to be replaced and the field coils to be replaced. At that point you have more into it than a 12 genny would cost. It might need different bushings if the armature is a different dia. So get the 12 volt genny. And a 12 volt regulator.
Steve H
