10 members (Gray_Ghost, Nick in Manitou, Gdads51, Jon G, Otto Skorzeny, Hotrod Lincoln, walter74, LAROKE, 2 invisible), 107 guests, and 3 robots.
Topics128,131
Posts1,056,372
Members48,441
#1026006 05/04/2014 12:53 AM
1 Offline
where can i get the spring that goes on bottom of vent window to put tension on vent so it doesn`t flop in the wind. if anybody knows the size?
the swap section, very specific spring, used is all there is, also some other critical parts involved, see some pics here
1955 1/2 resto, I feel sure I seen them somewhere on a vendor's page but I'm getting old and forgetful.....however, put an ad in the swap meet Parts Wanted Forum. Someone may have a parts truck. If no one has one in a couple days send me a PM and I'll let you have the one I've been saving as a spare!
What are the dimensions of those springs? Do you
suppose die springs would work as a replacement?
DG
Denny G
Sandwich, IL
New member...over at the lake... was trying to see if you could direct me as to where I could get a tool to put the rubber seal strip in the window seal.
