7 members (kades51, Southerntruck, Gray_Ghost, Bill Hanlon, Otto Skorzeny, JW51, MRMEROTH11),
82
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,133 Posts1,056,396 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 5 New Guy | | New Guy Joined: Mar 2014 Posts: 5 | where can i get the spring that goes on bottom of vent window to put tension on vent so it doesn`t flop in the wind. if anybody knows the size? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the swap section, very specific spring, used is all there is, also some other critical parts involved, see some pics hereBill | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | 1955 1/2 resto, I feel sure I seen them somewhere on a vendor's page but I'm getting old and forgetful.....however, put an ad in the swap meet Parts Wanted Forum. Someone may have a parts truck. If no one has one in a couple days send me a PM and I'll let you have the one I've been saving as a spare! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | What are the dimensions of those springs? Do you suppose die springs would work as a replacement? DG
Denny G Sandwich, IL
| | | | | Joined: Jul 2014 Posts: 12 New Guy | | New Guy Joined: Jul 2014 Posts: 12 | New member...over at the lake... was trying to see if you could direct me as to where I could get a tool to put the rubber seal strip in the window seal. | | |
