4 members (Gdads51, rfs56trk, 60steve, Wheelie), 69 guests, and 2 robots.
Topics128,212
Posts1,057,465
Members48,471
Moderated
Moderated
I was wondering if anybody knew if the PTO off of a 1944 Chevrolet 4x2 Civilian with a five speed tranny and chevy engine would fit onto a 1942 Chevrolet 6x6 with a five speed tranny and GMC 270. Any help would be appreciated. Thanks.
1 Offline
OLBLUE1941,
I've found after getting into a 6x6 CCKW build, that very little if any thing in the running gear of a civilian truck fits a military one. I may be wrong but everything was different in my 6x6. There are folks here that will know so just hang on. Welcome to Stovebolt, send some pics when you can post them.
1936 Chevrolet 1.5-ton SWB
"Murtahg"
More pix on Photobucket
It's only original once.
24601
24601
If we can't help you here (and I hope we can wink ), you can certainly try steelsoldiers.com or http://www.cckw.org/ or http://g503.com/
Hope you find the info!
Thanks for stopping by stovebolt.com
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Need to clarify what you have...Chevrolet never made a 6x6, nor did it have a 5 speed, or a GMC engine. You may have a cocktail as installing GMC engines and 5 speed transmissions into Chevys is/was a common occurance.
Lots more pictures
V
V Offline
If I remember correctly the CCKW has a clark 5 speed. Im sure you could find a pto for such a tranny.
1948 Federal 25M
1947 Farmall M
This story is also on the Gallery page
I thought that P.T.O.'s were universal units,as far as mounting plate configuration. The difference may be that the older units incorporated straight-cut gears,as opposed to helical-cut. I've seen SM 420's with plates on both sides of the case. hope this helps.
Mo' Tater
Willy,
The PTO 6 mounting bolt pattern is an SAE standard, but the driven gear has to match your specific transmission...some have straight cut gears and some have helical.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks,Mike. I changed my post.
Mo' Tater
Moderated
Moderated
Thanks for all the help. I misunderstood the guy on the phone, it is a GMC 6x6, not a chevy. I was aware of the difference in gears, I was just curious if anyone knew if it was a direct fit. Once again, thank you.
