4 members (38Kiwi, UtahYork, dt235sd, Hotrod Lincoln), 123 guests, and 2 robots.
Topics128,196
Posts1,057,390
Members48,471
Last Sunday, I drug poor SWEET on a long 500-mile loop across the eastern Virginia shore to fetch up a 1954 235 motor that New_Ton could not take with him on his move south. The motor was in the bed of New_Ton's 54 3800 when he bought it and it was rotating free when he checked it then.
We have no idea what condition this thing is in, but I did not want to see this thing go to scrap, so I fetched it up. It helped that I really had no idea how long a drive it would be. Twelve hours later, we rolled it into SWEET's garage, to sit next to his spare 261 until Homecoming.
We started the journey early from SWEET's house. Did some sightseeing on the route 13 bridges and tunnels, stopped for some local flavor (commit that one to memory guys...not recommended), and ended up at New_Ton's house around 1245. After dutifully gawking at his 3800, where I should have taken pictures, we loaded the engine up in my truck and headed home.
A couple of shots of the engine:
SWEET and engine
Missing road draft and rust on crank
Manifold Side
Engine number stamp...something like 0316117...
There are a couple of bolts that are snapped off in the block, but no big deal. We hope to drag this thing to Homecoming and see if SWEET's magic is intact. I am betting "Yes!"
Meantime, we're short a starter (SWEET is checking the flywheel tooth count for me), both manifolds, some flywheel bolts, a road draft tube, and a few other odds and ends. Hoping to scrounge these either at or just before Homecoming. It came with the flywheel, bellhousing (with most of the stomp starter linkage intact, minus the foot pedal part), and an engine stand. New_Ton really took good care of us there and his engine will find a good home.
See you all at Homecoming!
Jim
P.S. Many ODSS kudos to SWEET for helping a Brother out with the heavy lifting and grunt know-how.
1957 Chevrolet 3100 Stepside
235, 3-speed w/OD
24601
24601
Jim. I might have a starter and road Draft tube for you. Will check later today.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Thanks John,
We talked about swinging by your place on the way home, but the road was pretty long by that time.
Appreciate the help. We'll see if we can get it running after we finish with Charlie.
The ring gear looked pretty toothy, so I am not sure if someone converted this one to 12v. SWEET's going to count it up for me.
See you soon,
Jim
235, 3-speed w/OD
ODSS Lawman
ODSS Lawman
That was a fun Sunday. Kinda windy but fun. I had never been to that part of Va. Now I can check it off the list.
I counted the flywheel teeth. 168. That's a 12 volter right?
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
It was great meeting you and SWEET this weekend. Sorry you didn't enjoy the food where you stopped. There are some good places to hit on the shore but most are slightly off the beaten path. I look forward to moving to NN if just for the fact I'll be around the ODSS. Take care!
They are having a get-together this weekend (see above). I know you're really busy with the move, but at least take note of the names in the group. Most of those guys would love to work on your fantastic truck with you.
Thanks again for the gifts.
Best,
Jim
235, 3-speed w/OD
Okay, took too long, but here's the engine serial number decoded:
0016117T54XB
0016117 - Engine 15,116 from the New York Plant
T - Tonawanda, NY
54 - 1954 model year
XB - 3800 series
We found out at Homecoming that we have the wrong flywheel for it, so the search begins. Was a shame too, because we had everything else we needed to start the thing. Including empty beer bottles.
Jim
235, 3-speed w/OD
Thanks for the diner review. Been thinking about trying it since it's only about 25 minutes down the road. Won't bother with it now. I'm not to hard to please but the wife runs about 50% on Food approvals.
Moderated by  Bill Marlow, SWEET
