2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | I am pretty sure these didnt come with them from the factory, but I would like to install some anyway. Problem is the moon hubcaps wont fit due to the axle sticking out past the wheel so far. Has anyone come up with a workable solution?
1950 Chevy 3600
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | The original caps on the 3600 were large enough to clear the hubs but some repops do not clear. I've used a spacer between wheel and drum to move wheel out. Now running repro of originals. | | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | I take it the spacer doesnt cause any issues with the tire being too close to the fender? Mine is all in pieces currently getting painted this week so can't check.
Where did you order yours from? LMC?
1950 Chevy 3600
| | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | where did you get the spacer, and do you know what size you had to use?
1950 Chevy 3600
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | These 8 lug spacers come in various thicknesses, try tire shops or even on line. You can't go to thick with the spacer, limited by stud length. Also I used some peal and stick rubber weatherstrip on inside edge of cap to give a bit more space. This was on my flatbed so have no fender to worry about. Good luck | | |
