7 members (TUTS 59, Bill Hanlon, Otto Skorzeny, 50Chevy3100, cmayna, UnclePaddy, 1 invisible), 129 guests, and 3 robots.
Topics128,042
Posts1,055,509
Members48,424
#1024217 04/25/2014 3:57 PM
I am pretty sure these didnt come with them from the factory, but I would like to install some anyway. Problem is the moon hubcaps wont fit due to the axle sticking out past the wheel so far. Has anyone come up with a workable solution?
1950 Chevy 3600
Bradw1876 #1024220 04/25/2014 4:05 PM
The original caps on the 3600 were large enough to clear the hubs but some repops do not clear. I've used a spacer between wheel and drum to move wheel out. Now running repro of originals.
1946 1/2-Ton Chevy
I take it the spacer doesnt cause any issues with the tire being too close to the fender? Mine is all in pieces currently getting painted this week so can't check.
Where did you order yours from? LMC?
1950 Chevy 3600
Bradw1876 #1024222 04/25/2014 4:09 PM
where did you get the spacer, and do you know what size you had to use?
1950 Chevy 3600
Bradw1876 #1024278 04/25/2014 9:22 PM
These 8 lug spacers come in various thicknesses, try tire shops or even on line. You can't go to thick with the spacer, limited by stud length. Also I used some peal and stick rubber weatherstrip on inside edge of cap to give a bit more space.
This was on my flatbed so have no fender to worry about.
Good luck
1946 1/2-Ton Chevy
