7 members (DavidBraley, Otto Skorzeny, J Lucas, 66flea, Rosco, 55shaker, 1 invisible),
122
Mod | | | Forums66 Topics128,283 Posts1,058,504 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 61 | I'd like to install belts in the 1953 9300 GMC that I'm working on and wondered of anyone here has attempted that. My main concern is where to mount the top point of the belts.
Whenever you leave behind failure that means you're doing better if you think everything you've done has been great you're probably dumb -Louis CK- '53 GMC | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I wan't answer you question directly,but another option is putting in seats with seat belts incorporated in the seat. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | This is your best bet, the same product as DADS linked to above. Juliano's CLICK HERE | | | | | Joined: Aug 2010 Posts: 70 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 70 | I took the seat belts, along with the seat, from a '91 Chevy full-size pickup and put them in my '53 3100. It worked fine. I would suppose the top point (meaning the shoulder harness) would matter where the seat is mounted and how the person is sitting in the seat. I mounted the seat first and then put the seatbelts in place around the seat.
| | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | I just did the Juliano's 3 point belt install and according to Deve's tip page. It was completed in a little more than 3 hours. I am quite pleased with the way the belts fit and feel. Jerry Jerry
| | | | | Joined: Sep 2013 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 61 | Thanks guys, they look like they should be pretty easy to mount If a add a plate to the cab or something.
