2 members (2-Ton, Bill Hanlon), 82 guests, and 3 robots.
Topics128,142
Posts1,056,485
Members48,441
#1018791 04/01/2014 11:37 PM
In a few days I'll get the body parts back from media blasting. I'm going to do the body work and paint myself so I want to build carts and have them ready. The cab seems pretty straightforward; 4x4's into a cube with dimensions that roughly match the cab's footprint and casters on the bottom. But I'm wondering about the best way to handle the bed.
Anybody have pictures of what they made? or other suggestions?
A VW guy trying his hand at a '59 LB fs. Lots to learn, but it's about the journey.
Gas Pumper
Gas Pumper
I have two carts. One is the cab dolly and I made a platform with wheels, then put a pedestal on top of that to emulate the cab mounting. I can set it on the floor for most work, but also on the firewall and even tilted to a firewall/roof combo so I can get to the underside areas better.
The other cart is in my bolt bucket and is configurable to put a bed on, fenders, hoods, panels, you name it depending on the attachments. I even put the front and rear ends on it to work on them.
I also made a frame rotisserie that has raise/lower, rotates 360 degrees and rolls nicely. Made the bulk of that out of modified engine stands.
Other than those things, tables that put things at a comfortable working height are nice to have.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Your shop is bigger than my house. I'm working in one half of my 2-stall garage. Unless you're interested in trading spaces!
Nice shop!!
The easiest way could be to use sawhorses, run 2x4's or 4x4's across them, set the bed on top. Nice height, cross members holding the whole thing up, easy access to both fenders.
A thought.
Gas Pumper
Gas Pumper
Lots of pretty cool solutions on garagejournal.com for fixtures and jigs once you exhaust all the info here. I have seen some of the finest trucks on the road being restored out of a small garage. Good Luck! We are here to help!
Deve
The Think Tank
...here Lowe's will sell you black pipe and cut it to length for free. I made a couple "stands" to set my panel body on by figuring my lengths and by using "T's" I was able to build my stands for the price of some pipe and then just screwed them together. I did use some wheels a friend donated and I was all set.
Sir Searchalot
Sir Searchalot
In a small space, you may find standing bed on end works. Lashed to wall for safety.
Well Shoooot, Mine's been standing on it's tailgate for nigh onto 3 years now and I just hope the ceiling hasn't settled any.... I only cleared the fluorescent lights by a whisker when it went 'up'.
Reminds me I should check that bunji...
Give me ambiguity
or give me something else
No room for a cart in my two car garage with half designated for truck restoration. I simply restored the frame first, then protected it while the cab was at the media blasters. When the cab came home, I put two 2x12's across the frame and a sheet of 3/4" plywood over the 2x12's. The cab set on top of the plywood. All cab work was done while it was sitting on the plywood at a good working height. I built a gantry crane to move the cab around and the crane also straddled the truck frame while not in use.
Found a photo showing what I did. Basically, the truck frame was a large work bench...still is until I finish the bed which is my last project and she is done. Started on the bed last week.
I installed some casters on the bed to roll it in and out of the shop, Bed Mobility Casters, and put it on my lift to work on it.Bed on Lift
Back Out In The Sunshine
Gas Pumper
Gas Pumper
The passion for this hobby really brings out the inventiveness in everyone. Its pretty cool to see what people come up with. My solution takes up a 5 foot by 4 foot footprint so if you have a small garage, that's out. Yet, you see so many really awesome trucks come out of these small spaces. Goes to show you, real estate has nothing to do with it.
Deve
The Think Tank
David F...is that a pc of 2X4 steel tubing on top of your gantry crane? Can't possibly be a wooden 2X4! And what did you use for the braces? Looks like 3/4 aluminum tbng hammered flat on the ends? I like it since it will break down easily when finished.
Allen
1974 Stingray Corvette
Yes, heavy wall steel tube. Can't remember wall thickness or size, but 2x4x3/16 seems about right. The rest is 4x4 wood and 3/4" electrical conduit with ends hammered flat. All is bolted together and is now broken down and stored away. I used it for cab lifting and engine hoisting.
Authorized Pest
Authorized Pest
There are several Tech Tips regarding Cab Dollies on the site. Not sure if any of them, or a combo thereof might help.
Peg
~ Peggy M
1949 Chevrolet 3804
Thanks Miss Peggy
Allen
Gas Pumper
Gas Pumper
Yes, make a cart that is intuitive in that you can set the cab on the floor as normal, but you can also set it on the firewall and also the toeboard. I am in the middle of all the sanding, bondo, sanding, painting, etc etc and I use all three setups ALOT. I don't have the room for a gantry, so I decided that BEER is cheaper and takes less room. GIT-R-DUN!
Deve
The Think Tank
