| | | Forums66 Topics128,007 Posts1,055,275 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 98 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 98 | What's the best way of removing screws with out busting them off. Look to be original or they've been on for a long time. I've been soaking with wd40, with no luck, tried a hammer & screw driver still not budging. maybe some heat or is there a better solution. Thanks in advance.
1952 Chevy Suburban 1964 Chevy Suburban 1965 Chevy Suburban 4X4 1941 Chevy Truck 1948 Sedan Delivery 2000 K2500 Suburban 2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
| | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | WD 40 is probably the least effective product for that purpose. I use a product called Monolex, but there are many that work well. Even good old liquid wrench or PB Balster etc. Lots of patients, and I still had to drill out a couple of mine, and sometimes a little heat will help get the penetrant to get in and do its job. In the end I had to buy a new frame because I felt it was too far gone. You can't really tell until you get it apart and the glass out. Scott | | | | | Joined: Mar 2013 Posts: 235 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 235 | I like Kroil - just needs a repetitive application sometimes. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Aero-Kroil, an a little heat and lots of patience. After that anything goes! | | | | | Joined: Jan 2006 Posts: 98 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 98 | Is Aero-Kroil available at the local parts house? Thanks for the input
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Perro, Check the home page. You can call them & they will tell you who sells it in your area. Kroil Slow & easy does the trick. The frame is thin be careful with the heat. HArold
Harold Is a restoration ever finished? | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Before you worry to much look very carefuly around the bottom corners. The frames tend to rust and expand both inside and outside. It will crack at the thin edge. Also I was unable to get the internal v bar in the middle out because of rust. You will likely have to replace. My point just break or drill the screws. Plan on replacing the v bar that holds the two halfs together. I think you will find there is plenty of repair to do. | | | | | Joined: Jan 2006 Posts: 98 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 98 | Thanks, Just ordered some Kroil oil. They have a sale going on 2 king size cans for $14.50 +$5.95 shipping its an "msn offer"
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...the Aero-Kroil is pure penetrating oil. The Sili-Kroil is the same as penttrating oil but has some silicone in it as a lubricant. I keep two or three cans of each on my shelf. Best there is although there is a home remedy that is close! | | |
