8 members (Jims46, 2-Ton, Otto Skorzeny, tclederman, Bill Hanlon, Millenimech, dt235sd, greenie-reddy),
131
Mod | | | Forums66 Topics128,191 Posts1,057,365 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Everyone wanted to know what overload spring bumpers I was looking for. Here are the photographs of what I need:
[URL=http://s1290.photobucket.com/user/atldoverde_58/media/overloadspringbumpers_zpsc4dfd29a.jpg.html][/url]
[URL=http://s1290.photobucket.com/user/atldoverde_58/media/overloadsprings2_zpsd73fcf8e.jpg.html][/url]
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I can't picture where this at on the truck?? I'm not that familiar with the lever shock set up on the early truck. Is this the bumpers on the front suspension??
John | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | John, These bumpers go on the frame at the rear of the truck. The overload springs ride on these bumpers when you have the bed loaded down.
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I've never seen overload springs for a 1/2 ton. Usually only 3/4 ton and up had overload springs on them. John | | | | | Joined: Apr 2012 Posts: 35 New Guy | | New Guy Joined: Apr 2012 Posts: 35 | I've never seen overload springs for a 1/2 ton. Usually only 3/4 ton and up had overload springs on them. John And the ones I have seen do NOT have a rubber bumper on them.
An elephant is a mouse built to government specifications.
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | I have never seen those either. They almost look like bump stops.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Well guys, You may not have ever seen overload springs on a 1/2 ton, but there is always a first! These came on my truck which only had 2 previous owners. The owner before me did the paint and body work and the owner before him was a farmer from Topeka, Kansas. The guy I bought the truck from said everything on the truck came on it as is when he purchased it. Now, does anyone know where I can find these overload spring bumpers, or the rubber inserts for these bumpers?
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Got me where to find replacements? Might try Steel Rubber Products or Metro rubber see if they have anything you might adapt or use.
John | | | | | Joined: Feb 2008 Posts: 1,124 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,124 | I don't know if this will help, but on my '46 half ton project, overloads were installed and apparently used frequently. I've seen at least two others with these same overloads. As I understand it these were all aftermarket additions and are not shown in the accessory catalog.
I recall seeing replacements rubber bumpers, but don't recall where. They were outrageously expensive IMO. I decided to make these myself, given the truck was never going to be used to haul grain or other heavy loads again anyway.
An inner rubber slab from a skid steer tire was used. Regular tire rubber was tried, but it was much to stiff and wouldn't flex enough to fit into the bracket.
I can post photo links if anyone is interested. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Just FYI....my 37 did not have them but two other 37's "original" 1/2 ton pickups I've seen and worked on had them. | | | | | Joined: Apr 2011 Posts: 89 'Bolter | | 'Bolter Joined: Apr 2011 Posts: 89 | My 1954 3600 came with overloads that I believe to be aftermarket as well. Im the second owner of the truck, which was originally a farm truck here in MT. Seemed to be called Body Bouys, I haven't been able to find much info on them. Pretty interesting design tho.
Pics are near the bottom of the first page under 'suspension' if you click on the link in my signature.
Don't think they are quite what your looking for, but Classic Parts sells a front axle bumper (P# 74-921) that may fit your overloads, or could be modified to. On that note, if you can find a nice solid chunk of rubber you could probably make your own.
Chooglin
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | You can see the overload springs that were a dealer option in 1950 in some of my bolt bucket pics. Nothing that looks like what you have in your pics, but 49 could be much different. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | my 1951 3100 Chevrolet pickup had the same set Denny shows above in his post.I still have them put away,you don't see them very often.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Dint see them Deve, think you could post a link to the page????
DG
Denny G Sandwich, IL
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Might be this one ...link... | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Think I've found the rubber inserts that may work.Found them on Metro Rubber Products website under universal parts Pt# XB11. $30.55 a pair. Going to measure and give it a try.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Ah yes, thanks Gus, blink an eye and you can miss those little buggers.
When you say dealer option are you talking about an aftermarket item like JC Whitney or Western Auto, that the dealer might install Deve??? I don't think I've ever seen any like those, don't look substantial enough to give you much of a boost.
Denny G
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | It looks like there was not GM dealer option (RPO) "helper" auxiliary spring for 1949-standard ( RPOs ) or 1950-standard ( RPOs ) 3100/3600 Chevrolet truck. There was a GM RPO heavy-duty 3100 rear spring-set in both years, but it looks like they were still a semi-elliptic set of springs. As posted above, Dealer/Owner added non-GM auxiliary springs were available. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I think it was Jim Carter that told me that they are very rare, dealer installed option. Not sure what that means. I have a second set for my next project. I don't see them very often for sale. Kind of like the underbed spare tire carrier lock and a few other things that don't come up for sale very often. They are designed specifically for this vintage chevy or gmc truck since they fit the spring perches exactly right. Not for certain on anything. I wasn't there like you. LOL! Chevs of the 40's sells the new rubber bumpers for them. | | |
