1 members (NJC),
86
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 17 New Guy | | New Guy Joined: Jun 2007 Posts: 17 | I have a 64 c10. All the lights are working except the headlights. No blown fuses in the fuse box. The headlights were working about a month ago. Is there a headlight relay and where is it? Does it sound like the headlight switch is bad?
Thanks! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I don't beleive there's a re;ay on that year truck, nor are the headlamps fused through the fusebox. The headlamp switch has a built in circuit breaker for the headlamps. Try checking the connections at the switch, could be a loose connection. Also check the wireing at the lamps themselves. There is a ground wire up there, could be that, too.
Bill Burmeister | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 64shrty, Welcome to the Stovebolt. I think the headlights go from the the light switch through the dimmer (hi-lo) switch, so that might be something to look at too. I have enclosed a link...it's for a GMC, but it might crossover to your C10. http://www.6066gmcguy.org/Electrical-01.htm Stuart | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Start with a voltmeter or test light ...i would bet on corrosion ...and a bad ground .just start at the switch an follow the current ...till it stops . | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I had the same problem, checked it out as noted above. Found I had kicked the wire to the dimmer switch partially loose. | | | | | Joined: Feb 2001 Posts: 25 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 25 | I had a similar problem with my truck...I had a short in my hi/lo switch. I put in a new one, and all was great!
Bernard Laiben 1951 3100 Chevy Deluxe Pick-up (original with 73,000 miles on a "straight Six" 216)
| | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | dimmer switch! if you have any kind of water leak in the windshield or cowl area it seems to run right into the fuse panel and then the dimmer switch. | | | | | Joined: Jun 2007 Posts: 17 New Guy | | New Guy Joined: Jun 2007 Posts: 17 | I haven't had much time to look at it. About the dimmer switch, funny thing is I didn't even have a dimmer switch and the headlights were working.
I have a new dimmer and wire that I haven't put in yet.
I bought a new headlight switch, since it was cheap, and went to put it in but now I can't get the old knob out. I'm pressing the button and pulling but it won't budge.
Thanks for all the advise so far! | | | | | Joined: Jun 2007 Posts: 17 New Guy | | New Guy Joined: Jun 2007 Posts: 17 | Hey! The headlights are working! Turns out somebody just shorted the connector to the dimmer with a piece of wire and it fell out. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Let there be light....errr, lights! Yay! Stuart | | |
