3 members (KEVINSKI, dt235sd, Bill Hanlon), 109 guests, and 2 robots.
Topics128,049
Posts1,055,675
#101417 07/02/2007 12:51 AM
I have a 64 c10. All the lights are working except the headlights. No blown fuses in the fuse box. The headlights were working about a month ago. Is there a headlight relay and where is it? Does it sound like the headlight switch is bad?
Thanks!
#101418 07/02/2007 12:55 AM
I don't beleive there's a re;ay on that year truck, nor are the headlamps fused through the fusebox. The headlamp switch has a built in circuit breaker for the headlamps. Try checking the connections at the switch, could be a loose connection. Also check the wireing at the lamps themselves. There is a ground wire up there, could be that, too.
Bill Burmeister
#101419 07/02/2007 2:33 AM
64shrty,
Welcome to the Stovebolt. I think the headlights go from the the light switch through the dimmer (hi-lo) switch, so that might be something to look at too. I have enclosed a link...it's for a GMC, but it might crossover to your C10.
http://www.6066gmcguy.org/Electrical-01.htm
Stuart
#101420 07/02/2007 5:15 AM
Start with a voltmeter or test light ...i would bet on corrosion ...and a bad ground .just start at the switch an follow the current ...till it stops .
1952 Chevy Shortbed
Photos in Photobucket
#101421 07/02/2007 1:49 PM
I had the same problem, checked it out as noted above. Found I had kicked the wire to the dimmer switch partially loose.
#101422 07/03/2007 7:34 PM
I had a similar problem with my truck...I had a short in my hi/lo switch. I put in a new one, and all was great!
Bernard Laiben
1951 3100 Chevy Deluxe Pick-up (original with 73,000 miles on a "straight Six" 216)
#101423 07/06/2007 4:25 PM
1 Offline
dimmer switch! if you have any kind of water leak in the windshield or cowl area it seems to run right into the fuse panel and then the dimmer switch.
#101424 07/11/2007 2:04 AM
I haven't had much time to look at it. About the dimmer switch, funny thing is I didn't even have a dimmer switch and the headlights were working.
I have a new dimmer and wire that I haven't put in yet.
I bought a new headlight switch, since it was cheap, and went to put it in but now I can't get the old knob out. I'm pressing the button and pulling but it won't budge.
Thanks for all the advise so far!
#101425 07/11/2007 2:29 AM
Hey! The headlights are working! Turns out somebody just shorted the connector to the dimmer with a piece of wire and it fell out.
#101426 07/11/2007 2:47 AM
Let there be light....errr, lights! Yay! smile
Stuart
