0 members (), 166 guests, and 2 robots.
Topics128,196
Posts1,057,386
Members48,471
I have a 1951 GMC 1-ton flat bed that I am working on. I bought the truck about 6 years ago and my original plan was to build it back like it was when new. Since then I found that this is a very difficult process which requires a lot of research and the parts are hard to find. The biggest reason I decided against a restoration was the fact that this truck will only run about 40 or 45 mph down hill. My father had a 1978 Chevrolet C-30 that he used to pull a 36’ stock trailer for several years. He eventually bought a Kenworth to haul the cattle and the ton truck was sold to my uncle. My uncle put only about 5000 miles on the rebuilt 454 in the eight years he had it. I decided to buy the truck from my uncle and use it for the donor frame, motor, trans, rear, basically the entire running gear. Since then I have removed the 78’ cab and installed the 51’. The way I had to do it was to keep the finders in tact with the cab while I fitted the cab to the frame. My main concern was for the wheels to be center under the fenders. I measured and measured to make sure everything lined up, then built the cab and radiator supports. The 454 is rather large and the way the motor and transmission are mounted in the newer model frame in relation to the wheels made the motor further towards the front of the truck than the original frame would have. This is not a real big problem since there are electric fans and short shaft water pumps (which the engine already had). The face of the water pump pulley ended up being about ¾” from the backside of the radiator. I currently have the original radiator in the truck and I am looking for a new one. I want to make sure the 454 stays cool. I have been calling several different vendors about the radiators and everyone says that theirs will keep it cool. I don’t know how much I trust their salesmen. I have asked for flow and cooling data but they don’t understand. I will continue the search.
One of the good things about using the 78’ running gear is the fact that you have power steering and power brakes. The pedal system also works great on the AD trucks because of the distance the dash is away from the fire wall the whole assembly will just basically bolt in. I am using the hydra-boost braking system from the 78’ truck and the power steering. I have had a difficult time with the power steering which come not from the pieces fitting together but from a lack of knowledge and experience. I was connecting the steering linkage and decided to drill a hole through the input shaft off the power steering gear box to the hold the u-joint. This is a bad idea the input shaft is a two piece shaft that holds the guts to the rotary valve inside the gear box. This hole I drilled allowed the fluid to be pumped out. I found another rotary valve but now I only have ps to the left. I am going to have to buy a new gear box. The fuel tank that I am using is from an S-10 Blazer, I have it installed inside the frame behind the rear wheels. I have run new fuel lines and the motor starts and runs great. I do not have glass so I cannot get the truck on the road yet so I just putt around in the yard. Right now I am sanding all the paint and rust off the body and just piddling with it here and there. Once I get the paint off and the new radiator then I will determine the color and get started painting. I am thinking of a dark midnight blue.
I am a little new to the forum world and have done most of my research through the trail and error method. I think this is a great place to get a lot of experience and knowledge at your disposal in a relatively short amount of time. I hope I will have a little to add to the site. The information I have read in the forums thus far and the gallery stories are great. Keep up the good work.
The link below has photos of my 51 and my father's 46 we started these things together.
http://rides.webshots.com/album/567461654mqrReu
welcome to the Bolt. That is going to be a outstanding truck when it's finished.
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
That truck looks great! What are you going to do for the bed? Are you going to rebuild the original?
I am going to put on a modern steel flatbed by WW. It is the bed that was on the 78'. I am going to only have a half headache rack. I want the back of the cab to be seen from the rear. My intentions are to build this one to pull another. Since this is my first build I know that I am going to make many mistakes and find that there are alot of things I would do different. I have already discovered that a small block would be a better fit. And now that fuel prices are so high a 4 cylinder might even be better. I could never go the 4 cylinder route. I could probably do the 6 though my Dad has put a 235 in his 46'. I think that this truck would be cool to have either another AD truck or a nice Farmall or John Deere tractor sitting on a gooseneck trailer behind it. (maybe one day) The other responsibilities that I have prevent a lot of time and money to be dedicated to the project. My youngest who is 5 likes to go out in the garage and help me tinker on it. A few weeks ago he had to have the running boards installed. So what did we do? we installed running boards that were not ready to be on the truck but you do what you have to do to make the boy happy. Memories that will not be forgotten.
[quote=dsmith] I do not have glass so I cannot get the truck on the road yet so I just putt around in the yard.
I bet putting around in the yard is an understatement with a 454 under the hood!
Treasure those memories with your son AND TAKE LOTS OF PICTURES! Tomorrow he will be grown up and you'll be saying "where did the time go?" Enjoy--- welcome to the group.
Glenn
Welcome to the 'Bolt, dsmith! Great project!
1948 Chevrolet 1-Ton Grain Truck
In the Stovebolt Gallery SOLD
More pix in Photobucket
"A Man & His Truck--It's a Beautiful Thing!"
"You're never 100% ready, you're just next"....Ty Murray
Check this link to the slideshow of the truck. I have two short videos of the truck putting around the yard
http://community.webshots.com/slideshow/567461654mqrReu
cool cool
Certified Bolt Nut
Certified Bolt Nut
Looks like a great project!! Welcome to the Bolt
Dsmith,
I have a 49 chevy one ton flatbed and need to find the right size of rims to replace the old split rims and keep it a dually. Did you keep the original drums brakes on the rear? If so, what size rims did you get for the truck to clear those rear drums?
Joe
old49joe, its been a while since Dsmith has been here, since last August, until the first of this year in January.
NOTE: since this is the Welcome Centre everyone does not come here each time they visit the forums.
Here is the first post Dsmith has made since last August.
https://www.stovebolt.com/ubbthread...Main=146150&Number=996285#Post996285
In the link I posted he mentions he had made the swap and you could follow if in his photo bucket but pictures may not answer your question.
Since you are a new member and have only ONE post you cannot send PM's yet. You must have at least FOUR post and then you can send PM's (private message's) to him personally. New members are moderated for the first few post. It is to help keep the site safe and secure from spammers and such.
As moderator, I started to just take your post and move it to the driveline forum but will leave your post here since it is relative to the post before yours. Dsmith started this post about 6 years ago and probably does not come back here.
However, if you ask your question in the Genreral Truck forum or the driveline forum, you can still get an answer to your question...... there is a forum for ONE TONS, and even for BIG BOLTS.
There is lots of knowledge and info here so take some time to learn your way around the forums, view the tech tips, gallery pictures and the links listed.
Oh, welcome to the Stovebolt, Joe. You can find all your answers here. It just takea a few visits to get a handle on all that is here. Good luck..... and I know there are other bolters here from Idaho. Watch for them. Maybe some close to your house.
