2 members (Jon G, 1 invisible),
121
Mod | | | Forums66 Topics128,288 Posts1,058,571 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | ...got the 700 tranny in the panel. I'm taking the rest of the day off and will work out the little things next week. I do have the measurements for the driveshaft and ready to put the Bowtie Overdrive kit on it. | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | Put my drive shaft in and drove it, 58 GMC, up and down the road in front of the house for a few minutes. It's loud, no mufflers, and definitely has more get up and go with the 350 than the 235.
I know no pics then it didn't happen, well you'll just have to take my word for. I'll post some video when I figure out how to. Larry
58 gmc 100 with 350 sbc
| | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | Had a very good day, With a neighbor kid's help, got the Pertronix system successfully installed, all wiring cleaned up, also got a Tach installed and wired very neatly, and got the Fresh Air Heater unit pulled out for update to a 12 volt blower fan motor. If spring 2014 ever gets here, we will be ready to (have some fun). Jerry
| | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | got the clutch disk realigned, then got the trans back in... now to get the starter all hooked up and get this motor started! | | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | After a 4 week hiatus, back into the garage yesterday and pulled the rest of the dash out (gage clusters) and started removal of the wiring harness. Also removed the old heater (it was from an International) and getting ready to put my rebuilt fresh air unit in.
Now trying to psych myself up for dismantling the speedo. Pulling the needle and taking apart the odometer have me a little intimidated.
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | | | | Joined: Oct 2012 Posts: 8 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 8 | Rebuilt the master cylinder on the ole '49. Almost ready to get her back on the road. Waiting on some brake parts to come in from Jim Carter's.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: Aug 2013 Posts: 34 New Guy | | New Guy Joined: Aug 2013 Posts: 34 | Ok, not just today, but over the past several months I've been tinkering with the '54 panel. Rebuilt all the wheel cylinders, master cylinder and replaced all the rusted out brake lines. Changed out the tires and wheels at the same time. Took the bumpers and grille out and painted over that ugly blue with some satin black. Rewired the headlights and front parking/turn signals. Went over the wiring to the taillights and did away with all the corroded factory blade connectors, so now the head, tail and factory turn signals all work. Replaced the front t/s lenses with amber ones cuz I like 'em and I've got a new lense for the center taillight on order. Took the steering wheel off and cleaned up the turn signal switch. Now it not only works, but the self canceling part is functional. Fixed the horn contact while I was at it, so the horn also works now. Took the later model 3 speed shifter off and replaced it with the correct one so that the shifter clears the steering wheel now. Much easier to manuver in a tight spot. Posted some pics of the truck sitting at the gas pump on it's maiden voyage under it's own power in the truck album in my sig. | | | | | Joined: Sep 2010 Posts: 1,736 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,736 | Installed my new old canister filter. This motor now holds 9 quarts. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Sep 2012 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 20 | I have been tinkering around with all sheet metal off and engine still mounted. Decided to go all in today. Dropped driveline, removed tranny, and pulled engine. Sent head to machine shop and went shopping at sears. | | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Removed the RUSTED OUT pass cab floor and found a Crack in the frame. Time to fire up the HOBART Welder.
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Well, it was 87 degrees here yesterday and today night it will be 16 degrees. It looks the high tomorrow will be 35 and then back to the normal averages for the next 10 days. If that happens I will be spending time reupholstering my side panels
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | As many of you already know my truck has had it's fair share of handling 'issues'. I spent the day cutting and grinding all the old brackets off my rear axle in readines for a new Danny's Original Customs 4-link rear suspension. I'm loving the simplicity of it as it ties into the holes left by the removal of the front shackle mount rivets so there is minimal alteration to the original chassis. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Over the weekend, I got the floor mat installed, the door glass installed, a powered subwoofer installed, and the front grille readied for installation (poor weather prevented that install). After looking at the subwoofer photo, I am going to hide all the wiring under the sub. The wiring enters the cab directly under the sub via the factory "drain" hole.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Looking good David. I notice you have a CB radio installed. How did you run the antenna cable?
~Jim
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Not a CB, it is a PA system at the request of my son. I mounted in such a manner as no new holes were drilled and it can be removed without any tell tale sign it was ever installed. I hate it, but I conceded to my son as he will be driving the truck to and from High School when the weather is nice. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Just don't let him play "The eyes of Texas on it". lol
~Jim
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Shoot, if that was all he played, I would be happy. My father sense tells me it is only going to get him in trouble as it is also a siren (police, fire, ambulance) and very loud (100 watt speaker). It has a "radio" input setting (presumably so police/fire radio transmissions can be heard) that I connected to the radio (one channel from unused front speakers). So, he will be able to broadcast the radio outside the truck at stupid volume. I know, I know. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Just think, 25 years from now at the Thanksgiving table, the family will laugh about the night he spent in the Austin huscow. lol
~Jim
| | | | | Joined: Feb 2003 Posts: 1,391 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,391 | Getting the 40s aftermarket under dash mounted radio head painted and ready to install,it has a built in switch that will turn off and on the stereo in the glove box and will look like it has a period looking radio. | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Got 2 new/used Wrangler 225 R75-16's balanced and put on the front. (got 4500 miles on the 1st used set). Even tho they're used it almost feels like power steering  | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 |
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Rebuilt carb
Re set timing
Next. Adjust valves | | | | | Joined: Jan 2014 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2014 Posts: 30 | I pulled apart the dash and the heater on the Federal today. Got the blower motor working but the speedo is broke, if anyone knows where I can get my gauges rebuilt please let me know in a PM.
I also pulled apart the rear end, well to a point anyway. I am going to need a very large socket to get the hub itself off the truck... | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Completed one speaker box for 6x9 speaker to be located in rear cab corners (sorry no photo). Installed the grille. Very large pain in the neck to install, especially the two bolts above each running light/turn signal. Almost forgot...installed door panels, arm rests, window crank and door latch handles. I purchased maroon vinyl that matches the seat and covered a standard cardboard door panel. Armrest also matches...looks good. I will have a take a photo and post later. I looked at the grille photo again and just realized I installed the running light trim rings upside down. Doh!
| | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | got the accelerator linkages hooked up. Took off the starter to test it and clean the contacts/starter itself up. Finish that up tomorrow on my day off and hopefully get the engine fired up for the first time since I bought it! | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 |
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I have a 1981 Camaro 10 Bolt with a 3.73 gear set from a 1997 Silverado. I was able to just bolt on a 2002 Camaro/Trans AM 12" LSI rear disc brakes. Trans AM Read Disc Brakes
~Jim
| | | | | Joined: Feb 2003 Posts: 1,391 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,391 | Got the radio head togather and will be installing it tonight,the 37 will look like it has a vintage radio but its to turn on and off the stereo in the glove box and the dial will also light up and will post pics when its installed. | | | | | Joined: Feb 2003 Posts: 1,391 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,391 | | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | BEAUTIFUL 65 degree day!!!! Got the starter installed, carb hooked up, starter button installed, oil and plugs changed, tranny lube changed.... been a busy day! Tried to get the motor started... but it needs a little ignition work first! | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I bought a Sanden compressor and bracket for the '56 from Old Air. I got it installed today but I had to remove the alternator bracket to get the A/C bracket on. Now I need to go back and get their matching alternator bracket. Would have been nice if he'd told me it would interfere when he was looking at it to tell me what I need. | | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | Installed bluedots into my new stainless tail lights on Red Ryder. tail light pic
| | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | found a kink in the fuel line from the pump to the gasket... no wonder it was starving for fuel and not starting!  | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Over the weekend I got the alternator bracket to match the Old Air compressor bracket installed in my '56. Today I charged the A/C system. It isn't working right, dang it. | | | | | Joined: Feb 2003 Posts: 1,391 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,391 | Started assembling the heater and broke the knobs,new ones are available and hope to get them soon. | | | | | Joined: Oct 2010 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 55 | Finished blasting vent window frames, wind deflectors and shifting arm and the running board splash pans, got 'em all in primer. Once this darn cold front gets outta here in Virginia, I'll get to wet sand and paint 'em all and finally get all of the gaskets in place and vent windows mounted. | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Got the throttle linkage hooked back up and also he Bowtie Overdrive kit for the 700R4 tranny. I should be able to put the driveshaft in tomorrow if its ready.
...also re-routed a brake line better around the tranny. If I had a correct dipstick I could put fluid in it tomorrow and get "big Orange" back on the ground. Got a dipstick from Mr. Gasket that attaches to the firewall and its a big "joke". I'm taking it back and looking for an original style one!
Also adjusted the brakes just a little since its up on jack stands. Bad rainy and cold day outside but a good day in the shop! | | |
