5 members (Otto Skorzeny, 2-Ton, Wally / Montana, Lightholder's Dad, 1 invisible), 117 guests, and 0 robots.
Topics128,051
Posts1,055,730
#1008916 02/21/2014 11:20 PM
Has anybody ever shortened a steering column ???? Even with a 14" wheel still touches my big belly . If 4" out of column it would work just fine.
" STUCK IN THE '50'S "
1 Offline
How to shorten a steering colomn...
http://talk.classicparts.com/showthread.php?t=7908
Thanks 1951chevy1ton
Moderated
Moderated
Thanks for the link and your input, it will help me out.
Just good info. The column is shorten in this project to so it may help you some?
http://www.classicperform.com/tech_articles/Power-Steering-Trucks/Power-Steering-Trucks.htm
If you are asking about shorting a stock box and you are asking about a 1955 truck, then the easiest way would be to install a 1958-59 box. They are much shorter because they used a dished steering wheel.
I would need to measure some of my cores to tell you exactly how much, if you are interested.
My Blog
Dave,
I think the 57-59 column is 3.5" shorter (the amount of the steering wheel dish) which keeps the actual rim of the steering wheel the same distance off the floor on all of the TF trucks. With that said, this swap could help Wanderer 1955 if he has a newer dished wheel on a 1955 TF truck, as the stock wheel was not dished.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Then by using the 1957-59 box with a 1955 wheel it will move the wheel 3.5" away from him, about what he wanted.
My Blog
I cut 4.75" off my column & had it welded today ,. will install as soon as bearings are here ....
