| | | Forums66 Topics128,090 Posts1,056,381 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | What was the original paddle button switch for a 49? Did it say Heat or Air on the button?
Thanks.
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I have generally found Air associated with the Air Flow deluxe heaters and Heat with the Recirculating type. There are variations in color and text as some switches are labeled DEF into 1948 models. The correct switch will be labeled with Delco-Remy or Cole-Hersee markings on the side but even these are sometimes missing. I do not believe Ark-less or rotary switches of other makes to be correct for these applications. NOS heater kits contain the above referenced switches as part of the kit, they were also available separately from dealers. | | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 |
