3 members (Rick Brown, Otto Skorzeny, 1 invisible), 151 guests, and 1 robot.
Topics128,108
Posts1,056,239
Members48,437
Before shot was fresh from being a chicken coop in Missouri.
Had a 52 Olds motor with Hydro in it.. done in the late 50s or early 60s.
Now has 455 Buick Stage 1 w/ Turbo 400 ... still has the 56 Olds rear end that was in it when I found it.
Hope y'all like it!
http://s1367.photobucket.com/user/Roadmaster75/slideshow/1951%20Panel%20%20before%20and%20after
Y
Y Offline
Great looking panel, you can be proud of your results!
Sweet looking truck.
Great transformation!
Thanks fellas ....!
The worst part of the restoration was block sanding all that flat sheet metal!
Many holes for ladder hooks, CBs, clearance lights, etc had to welded up and
made to disappear under that black paint!
I almost hated to remove the ancient Olds motor and hydro but they were done for, and I wanted a truck to be able to haul an occasional engine or tow a trailer.
Beautiful panel. Nice work.
1937 Chevy 1/2 ton panel
Squire, that's a mighty fine job on the panel. Its nice looking to say the least. Way to go.
Looks great !
Did you " fade " the paint at the bottom of the door, or is that just shadow I am looking at ?
1940 Chevy KC 1/2-Ton
Thanks, Guys
- Britcon -
The gold is not faded. It is a shade called "Pacifica Gold".
Has a dark maroon pin stripe to separate the colors at the belt line.
mike
Wicked pissa! (That's a big compliment in Boston) : )
Larry Bear
55.5 Chevy 3100 Panel
That looks awesome! I love your choice of power!
My 46 GMC on Photobucket
Awesome !!!!!!!!!!!!!!!
1951 3100 Chevrolet
Nice job u should be proud
Hope I can mine going this year
FRANK
Thanks, Guys!
Still a work in process …… Trying to spruce up the cargo area
this winter & plan on installing A/C by the time the HOT weather gets here.
I'm going to try to use a standard GM A6 compressor that was on the Buick motor originally, but mate it to an aftermarket unit like Vintage Air, etc….
Since the motor already has the compressor brackets on it & the third pulley
is in alignment with the stock unit…I just thought it would eliminate re-engineering that part of the job… Not everybody uses a small block Chevy!!
The truck now has almost 600 miles on it ..runs cooler and cooler as the rings and bearings break in.
Thanks again for all your compliments!
mike
VERY nice panel
Weeds
THat is a great looking ride. Would love to see inside too.
RIck
Jack of all trades, Master of none, but I want to be.
RIck
RIck
