| | | Forums66 Topics128,021 Posts1,055,351 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The rear bearing on the output shaft is not a sealed bearing Bart. So the two spaces are common to each other. Just make sure to check the trans fluid level a few times after driving it a bit. As Tim points out, they will level out eventualy.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
