2 members (Oswald, Brian Moore),
139
2
Mod | | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a ground wire to the points distributor body is not necessary or original, but won't affect any thing, obviously it isn't "shorting" anything if you have fat spark to the plugs
you're using the Petronix coil with an original distributor, or you've gone back to the Petronix distributor again? have you tried the points dist with an original style coil?
you've checked the timing again? are you sure the dist isn't in backwards? is the advance mechanism on it good, both vacuum and mechanical?
Bill | | | |
Entire Thread
electrical conundrum...get ready, it's a doozy
| starsfan | 10/16/2012 3:38 PM |
Re: electrical conundrum...get ready, it's a doozy
| Grigg | 10/16/2012 4:15 PM |
| Flxible | 10/16/2012 4:21 PM |
| starsfan | 10/16/2012 4:33 PM |
| Flxible | 10/16/2012 5:18 PM |
| starsfan | 10/16/2012 5:40 PM |
| FriedGreenTmater | 10/16/2012 5:51 PM |
| bartamos | 10/16/2012 6:39 PM |
| DrewP | 10/16/2012 6:44 PM |
| LGriffin | 10/16/2012 7:49 PM |
| starsfan | 10/16/2012 9:24 PM |
| starsfan | 10/16/2012 10:09 PM |
| Cletis | 10/16/2012 10:44 PM |
| starsfan | 10/16/2012 10:49 PM |
| Roy Rodgers | 10/16/2012 11:06 PM |
| starsfan | 10/16/2012 11:09 PM |
| bartamos | 10/16/2012 11:16 PM |
| GWWirth | 10/16/2012 11:21 PM |
| starsfan | 10/16/2012 11:27 PM |
| Flxible | 10/16/2012 11:30 PM |
| bartamos | 10/16/2012 11:32 PM |
| hippy | 10/17/2012 12:40 AM |
| Hotrod Lincoln | 10/17/2012 9:48 AM |
| starsfan | 10/17/2012 9:59 AM |
| bartamos | 10/17/2012 10:56 AM |
| Flxible | 10/17/2012 11:03 AM |
| bartamos | 10/17/2012 11:08 AM |
| starsfan | 10/17/2012 11:20 AM |
| bartamos | 10/17/2012 6:01 PM |
| Donsz | 10/18/2012 7:56 AM |
| starsfan | 10/18/2012 9:46 AM |
| Hotrod Lincoln | 10/18/2012 10:40 AM |
| Grigg | 10/18/2012 10:15 AM |
| starsfan | 10/18/2012 10:39 AM |
| bartamos | 10/18/2012 12:38 PM | |
